Need push-rod advice please
Old Jan 31, 2011 | 12:19 AM
blackmagicturbo's Avatar
Default Need push-rod advice please
I am currently building a ls2 with boost and need push-rod advice ,, Dart heads (2.08 intake) .640 lift w/1.75 rocker ,, springs are 375lbs open ,,7200rpm rev limit, 20 +psi ,,,what brand would you guys /gals recommend ? please only parts that you have tried and succeeded with/ had personal experience with ,,Thanks
Old Jan 31, 2011 | 10:39 AM
Snyper's Avatar
Ive always had great luck with comp cams chromemoly pushruds.
Old Jan 31, 2011 | 11:45 AM
^^ 5/16 ,, no need for nothing larger ? ive had good luck with comp so far too (on .600 lift),, .640 is the most lift ive ran so far ,, just wasnt sure ,,thanks
