In need of a cam
Either LPE or EPS custom grind. LPE has the best FI cams out IMO as far as grinds go. If not one of those two go with a LS9 cam. But have a look at the LPE cams here are there grinds and specs of those grinds...
Lingenfelter GT1-1 229/242 .631/.631 w 1.7 rocker 114 CL
Lingenfelter GT2-3 207/220 .571/.578 w 1.7 rocker 118.5 CL
Lingenfelter GT11 215/231 .631/.644 w 1.7 rocker 118.0 CL
Lingenfelter GT7 208/230 .554/.546 121CL
Lingenfelter GT9 215/247 .629/.656 121 CL
I personally would go for the GT-1-1 or the GT9 for sake of duration and max effort. Those Mast heads will flow better the higher the lift you go up to .700 most likely. The GT9 and GT1-1 will give them the most benefit as will the GT11.
