Solid roller cam?
Old Feb 1, 2011 | 10:44 AM
LSXFORMULA99's Avatar
Default Solid roller cam?
I bought a forged 370 for my turbo build. it has a custom grind solid roller cam...
My plan was to buy a set of shaft mount rockers to be able to run the solid roller setup, Now thinking about selling to run hyd. roller. This is for more of a track car than street, Any of you guys running a solid roller cam? How often do you have to adjust and how much of a pain in the *** is it?
Thanks
Old Feb 1, 2011 | 10:45 AM
Zmg00camaross's Avatar
In for a response.
Old Feb 1, 2011 | 11:15 AM
87silverbullet's Avatar
ls2formula on here has a solid roller cam in his formula and drives everywhere in his car. It runs 7.90's
Old Feb 1, 2011 | 11:35 AM
damn. i hope he replys on here
Old Feb 1, 2011 | 01:28 PM
Here's his thread.
https://ls1tech.com/forums/forced-in...c78s-kytp.html
Old Feb 1, 2011 | 01:38 PM
98Z28CobraKiller's Avatar
Restricted User
While LS2Formula's car is a solid roller, it really doesn't need to be and wouldn't be if he hadn't already had the Jesel rocker system leftover from a previous high rpm nitrous build. Rocker adjustment is a pain in the ***. If you aren't intending on turning 8K RPM and running a 5/4 race cam, hydraulic is your friend.
Old Feb 1, 2011 | 02:11 PM
ok. i really dont want to take this cam out because everythings all together but i might have to...cobrakiller, I am doing a build similar to yours. what converter were you running on the 8.9 pass, how much boost? thanks
Old Feb 1, 2011 | 07:09 PM
Restricted User
I run an FTI converter and it stalls around 4500-4800 RPM. 22 psi to run the number at my 3850-3900# race weight.
Old Feb 1, 2011 | 07:11 PM
Restricted User
Also, what are the numbers on the "solid" cam. You may be able to just throw in hydraulic lifters and call it a day. The first 2 "solid" cams that we got from Comp had hydraulic lobes on them.
Old Feb 2, 2011 | 08:27 AM
i dont have the part number or anything. just the specs..how safe was that setup on 22psi? lift 647in/640ex duration over .050 242in/236ex 3500
comp cam solid lifters
Old Feb 2, 2011 | 10:09 AM
Restricted User
Yeah, I wouldn't use that cam.
Where is the 224/224 cam in your sig? That thing would work way better with a turbo than with a supercharger.
Old Feb 2, 2011 | 10:46 AM
i sold it..the guy i bought the motor from said its a custom grind for turbo setup. its on a 114lsa
Old Feb 2, 2011 | 07:28 PM
Restricted User
Unless those 317's have some work, they got nothing past .580ish lift. No reason to use a cam with all that lift when the heads are done flowing so much lower. I would keep lift closer to .600 on the cam. Also, those heads already have poor exh flow as com pared to their intake flow. I would have the split go forward instead of backwards. In a nutshell, that cam may be good for a turbo setup but not yours IMO.
Old Feb 2, 2011 | 08:26 PM
i didnt know that. If i get some work done one the heads it would work better..what cam were u running?
Old Feb 2, 2011 | 08:50 PM
Restricted User
What turbo do you plan to run?
I run a 232/232 595/595 114 hydraulic in mine. It's an off the shelf cam from Livernois. The stage 2 cam to be exact. I have AFR 225 heads.
Old Feb 2, 2011 | 09:59 PM
texas94z's Avatar
What in the hell is a 5/4 cam?
Old Feb 2, 2011 | 10:29 PM
Restricted User
You ever heard of a 3/4 race cam? It's lingo that the old timers used to use. 5/4 is a 1 1/4 race cam like all the local guys like to use and then want it to idle like stock.
Old Feb 2, 2011 | 10:36 PM
twinturbo496's Avatar
Life is too short not to run a solid roller.
I stole that.
Your knock sensors may not like a solid roller.
Old Feb 2, 2011 | 10:42 PM
texas94z's Avatar
Never heard that lingo before lol. What are the details of LS2Formula's high rpm nitrous build? Just curious about the heads, cam, and nitrous.
Old Feb 2, 2011 | 10:50 PM
Restricted User
Were. It's a turbo car now. It was basically the same as it is now but with a big cam. High 260's duration and lift in the 660 to 670 range IIRC. It's been a while. I'm trying to forget those days and it was so difficult to go fast. Boost is definitely the answer.
