Using a FMIC on a TA?
Old Feb 5, 2011 | 08:17 AM
383camaroz28's Avatar
Originally Posted by sschoeffler
I call BS on all opinions. It can be done and I did it.
I will pull up a picture for you.
BIG Front mount intercooler, fog lights still in use, intercooler is able to be covered up with the fill in (Good for car shows if you like)
Hey do you have any with bumper off? Im looking to do the same, an did u use a 31-12-3 ic?
Old Feb 5, 2011 | 11:05 AM
sschoeffler's Avatar
Yes I used a 31x12x3
Here is a pic for you
Old Feb 5, 2011 | 11:23 AM
02SOMLS1WS6's Avatar
Thanks guys this is all good input and opinions. Anyone with experience of running one with and without the cover and lights please step in.
Old Feb 5, 2011 | 11:31 AM
theres a guy on here with a red ws6 he has just the bird on the plate left and cut out the rest..
any pics with fogs mounted bumper off?
Old Feb 5, 2011 | 01:15 PM
meine96ws6's Avatar
it looks good behind there.
Old Feb 5, 2011 | 01:24 PM
It did look good, I am in the process of removing it all now. Sold the entire kit for dirt *** cheap. having regrets now lol. Oh well, on to bigger and better things. If I could just find the damn parts to put an F1A together lol
Old Feb 7, 2011 | 11:28 PM
00transamws6's Avatar
Sschoeffler, any pictures of how you routed the IC pipping? I'm in the process of buying an D1 with a epp front mount
Old Feb 8, 2011 | 01:16 AM
Yea man I can dig some pics up but how I did it is:
Looking at the engine of the car standing in front of it, the charge pipe come out of the throttle body and loops to the right. You have 2 fuse boxes over there. both fuse boxes are held in by a plastic cup. the fuse boxes slide out of the plastic cup and the plastic cup slides out of 2 little grooves in the sheetmetal of your wheelwell. under there is a hole big enough to fit your 3" intercooler tubing through. So after the piping comes out of the throttle body and turns to the right it will then turn down and go through that little hole that was covered by the fuse boxes. once it goes down about a foot you will want a silicone coupling there when you join your next piece of pipe. So after you loop it down into the whole it will then make a bit of an angle towards your intercooler and plumb into the drivers side of the intercooler.
From the head unit you will use a 45 degree coupler and that will give you a straight run to the left with your pipe. Use two 90 degree pieces of tubing and plumb it into the left side of your intercooler. Make sure you dont' use any 90 degree couplings because if you do you will blow them off or out. Besides that, pressurized air doesn't like to bend. I will dig up some pics tomorrow and post them.
