Using a FMIC on a TA?
Old Feb 4, 2011 | 04:38 PM
02SOMLS1WS6's Avatar
Default Using a FMIC on a TA?
I know many use a fmic on a TA, however how many of you use a FMIC without removing the fog lights and firebird plate cover?
I would like to run a fmic set up but dont want to remove the lights and cover and was wondering how badly that would hurt the intercoolers performance and if anyone uses a fmic like this.
I will be buying a procharget set up soon and they released there fmic set up and I am trying to understand for my situation of not wanting to remove the cover and lights if the twin 4.5" is still my best option.
Old Feb 4, 2011 | 06:56 PM
Frametwista's Avatar
maybe u should look into a different type of intercooling cuz its not going to work.Fmic and your gonna cover it up its useless it needs air flowing you have to make some sacrifices to the forced inductions god cant have it all.Maybe you can just spray it instead of fi
Old Feb 4, 2011 | 07:08 PM
David21's Avatar
Not possible with an Fmic, you could try side mounts
Old Feb 4, 2011 | 07:19 PM
JaYZeig's Avatar
maybe setup some type of thermostatic fan switch, when temperatures reach a certain point..itll trip the intercooler mounted fan to turn on and give you your airflow across the intercooler.
somthing along this?
http://www.summitracing.com/parts/HDA-3653/
Old Feb 4, 2011 | 07:24 PM
evo462's Avatar
A big fat intercooler peaking out of your bumper looks way cooler than lights or a plate filler anyway.
Old Feb 4, 2011 | 08:35 PM
20TA02's Avatar
^^^what he said... before i cut the lisence plate cover...
Old Feb 4, 2011 | 08:36 PM
Tally TransAm's Avatar
guys have horizontal mounted front mounts and used an air dam to deflect air through the intercooler up from under the car
it is definitely possible, just gotta get creative
https://ls1tech.com/forums/forced-in...c-project.html
Old Feb 4, 2011 | 08:52 PM
But how efficient is it compared to opening up that area?I bet it isnt at all if it was everyone would be doing it open her up and let her breath
Old Feb 4, 2011 | 09:13 PM
in factory configuration the radiator doesnt get any air from the front of the car and it is very efficient picking it up from the bottom. you can see from my sig pic the route i took, but theres always more than one way to get things done
Old Feb 4, 2011 | 09:34 PM
WS6sleeper's Avatar
What about say the APS twin turbo fmic? It mounts right behind the fogs/plate and folks are making stupid power with that kit. Maybe try to duplicate that intercooler mounting position and it'll keep the plate/fogs intact.
OR you can stick with the twin 4.5" intercoolers. Those are still pretty efficient, and could hold a fair amount of boost before you actually NEED a fmic. What are your goals for the engine setup?
Old Feb 4, 2011 | 10:09 PM
Aster's Avatar
I Laid mine down flat too. Works pretty well, and flows more air than the twins.
Old Feb 4, 2011 | 10:37 PM
Pretty modest goals really since I wont be upgrading the bottome end anytime soon, the car will probably be at 8lbs for several years before I step it up.
I just thought I would feel this out, because I know I have seen members on here with fmic's that dont have the plate cover removed and I was wondering how that effected the performance of the system.
Ditching the fog lights isn't that big of a deal, but I dont want to remove the plate cover not only because I like the look of the bumper with the cover on it but also my state requires a front license plate and even though I dont use one it isn't as obvious as an intercooler showing the law that the car means business, LOL.
Old Feb 4, 2011 | 10:38 PM
I do like the way your car looks in your sig. Real nice
Old Feb 5, 2011 | 12:56 AM
corpserodeo666's Avatar
Check it.
https://ls1tech.com/forums/lsx-parts...tains-air.html
This idea might work out for you.
Old Feb 5, 2011 | 01:44 AM
sschoeffler's Avatar
I call BS on all opinions. It can be done and I did it.
I will pull up a picture for you.
BIG Front mount intercooler, fog lights still in use, intercooler is able to be covered up with the fill in (Good for car shows if you like)
Old Feb 5, 2011 | 06:19 AM
David21's Avatar
I retract my previous statement. I be wrong
Old Feb 5, 2011 | 07:46 AM
2001WS6Vert's Avatar
I could be wrong but I would bet it would still work damn good without removing the plate or lights if it was in the standard upright location that most do here. I feel there would be enough air swirling around it with the aid of the air dam. When I had a FMIC I retained the fog lights and had a mesh over the plate area, it worked very well and I don't think it would have hurt much if the plate cover was also there. Someone who has retained the lights should do test results with the plate cover and no plate cover to see the difference.
Old Feb 5, 2011 | 07:51 AM
David21's Avatar
The difference is air wouldn't pass through the intercooler.
You need some sort of ducting to have air pass through. Swirling would be less than efficient
Old Feb 5, 2011 | 08:11 AM
I stand on my statement. The only way to prove me wrong would be before and after logging data. I agree that it would work better opened up but I don't think it would be the difference that some might think. Look at the third gen. Trans Am that have no air opening in front of the radiator, the air dam is what allows this design.
Old Feb 5, 2011 | 08:13 AM
David21's Avatar
Yea which is why they lay the intercooler flat instead of straight up. I see no advantage of standing it up unless you are going to remove the spotlights or license plate section.
