Hey any one ever seen the ARP 2000 7/16 bolts break ?
Im wonder has anyone ever seen the arp2000 7/16 bolts break in a aftermarket rod ? when installed only once ?
how long should they be run for ?
should they be replaced after every rebuild ?
When the bolts do need to been replaced is there any reason not to up grade to a arp 625+ or 3.5 bolt ?
when is the 625 or 3.5 bolt needed ? will these bolt last longer ? do they need to be replace more ?
