LMR Standing Mile Update #2
Old Feb 25, 2011 | 10:53 AM
  #41
GoldRust's Avatar
LS1TECH Sponsor / 7 Second Club
The turbos are a custom set built by precision turbo. They will support around 1300-1400 per turbo. It has a dry direct port with about 150 shot to help spool and cool the air. We will hopefully run 35-40 pounds of boost when turned up to run a big number. Which should get us 2000+ rwhp. We didnt change the gear ratio in the trans. But I can turn this thing to 9000-9500 rpm so I plan on only using 1st through 4th gear.
Old Feb 25, 2011 | 10:57 AM
  #42
LS1RedZ's Avatar
^^ Thats insane! Cant wait to see some results.
Old Feb 25, 2011 | 08:40 PM
  #43
S2K's Avatar
S2K
From: Bristol, TN/Knoxville, TN/Mooresville, NC/Phoenix, AZ
Compression Ratio? Rear gear ratio?
Old Feb 25, 2011 | 08:49 PM
  #44
02anti_vnm's Avatar
looks like a sick build
Old Feb 25, 2011 | 08:51 PM
  #45
GoldRust's Avatar
9.5 to 1 and a 2.56
Old Feb 25, 2011 | 09:54 PM
  #46
wilson34's Avatar
Totally ridiculous build, I love it!
Old Feb 25, 2011 | 10:59 PM
  #47
charlie_gonzales's Avatar
Originally Posted by My2kz28
Thats awesome you guys built a camaro when you could have built like a badass vette or something! Seeing that camaro go 250+ will give camaros a ton of respect for sure.
Theres a bad *** vette they built as well...rcc's vette is a red c6 z06...look it up...very badass
Old Feb 25, 2011 | 11:40 PM
  #48
mcm375's Avatar
Old Feb 26, 2011 | 07:02 PM
  #49
norcalauto's Avatar
who is going to pilot this crazy machine?
Old Feb 26, 2011 | 07:20 PM
  #50
FirebirdSS's Avatar
Amazing work! Kind of cool to see you guys are using the same injectors we are.
Old Feb 26, 2011 | 07:33 PM
  #51
dans776's Avatar
Look'n good guys, CAN'T WAIT TO SE IT RUN!!!!
Old Feb 26, 2011 | 09:06 PM
  #52
05HD's Avatar
Teaser shots look awesome.
How on God's green earth are you going to hook 2,000 hp at the TX mile?
Old Mar 1, 2011 | 11:31 AM
  #53
GoldRust's Avatar
I will be driving it as well, as far as traction, that is what i do. I use the same methods and technology that I use on our drag radial car. I just stay in it longer lol
Old Mar 1, 2011 | 12:34 PM
  #54
Worm Boy's Avatar
SHES ALIVE
http://www.youtube.com/watch?v=8uhPGWTOmLQ
Old Mar 1, 2011 | 01:15 PM
  #55
bigti99a's Avatar
sounds killer!
Old Mar 1, 2011 | 07:48 PM
  #56
White.Lightning's Avatar
Sick car. Maybe I missed it, but what engine management are you running?
Best of luck in the event!
Old Mar 1, 2011 | 10:55 PM
  #57
KagA152's Avatar
sick sick sick
what are you going to run for clutch and transmission setup?
Old Mar 1, 2011 | 11:24 PM
  #58
DiscerningZ32's Avatar
Originally Posted by 52172
Your totally right. In the USA there should not be foreign cars winning the races. Looking forward to seeing it run! Looks like you guys have some sort of rear diffuser setup? Definitly have to look at aerodynamics going 250 mph. Curious to see the front end on the car. Good luck!!!
Just so you know, the standing mile record was held by a Ford GT the last I checked. It went 250 something.
What made you guys go with a 4th gen vs something like a C6?
Also, what's your goal assuming all goes as planned?
Old Mar 1, 2011 | 11:34 PM
  #59
3.8redbird's Avatar
256 or 257 for the ford gt but that was on a screwy timing setup.
Old Mar 2, 2011 | 01:26 AM
  #60
FlashLCD33's Avatar
All of that and it still has power steering? :p
