STS updates?
Old Mar 10, 2004 | 01:56 AM
93formula's Avatar
yes the .ca stands for canada, we mainly try and focus on canadians but will ship to the US if needed.
as for the oiling system, thats what drives up the cost a bit, it itself is worth 500 bucks, and the turbo is designed specifically for the remote mount location, it wont work great up front nor will a tradional turbo work great in the back.
as for the availabilty, john peoples, the VP of STS has confirmed that there available now. rick has transfered a lot to his VP's so that may be causing some delays and confusions.
Old Mar 10, 2004 | 02:29 PM
BigPlanTransAm's Avatar
hah, i probably should have read the rest of the url
anyway, say you were to ship to new jersey.... any idea on how much that would be?
Old Mar 10, 2004 | 02:50 PM
YOUR03COBRA8ME's Avatar
3600 without meth
Old Mar 10, 2004 | 02:52 PM
Mine has been shipped
Big Plan I did a name chaNGE i USED TO BE I8YOUR03COBRA i talked to you a few times about the kit
Old Mar 10, 2004 | 08:49 PM
93formula's Avatar
send me your zip code and ill get back to you on shipping costs.
Old Mar 11, 2004 | 02:35 PM
edit: hmm, maybe i shouldnt post that on the internet, sent you a pm formula. do you know what the shipping weight would be with the meth injection included?
and what made you change your name cobra? did unit ?
Old Mar 11, 2004 | 02:40 PM
mongse's Avatar
I ruin the end of films...
Originally Posted by rons 00z
he uses a special turbo designed for his kit to reduce lag so you'll need one of those too.
It's not that radical of a turbo, just strange. You can't just go out and buy a standard off-the-shelf turbo to upgrade either.
Old Mar 11, 2004 | 02:43 PM
exactly, which is why i would rather buy from him and if i ever want to upgrade i could ask him what kind of specs i should get or ask him to build one for me. it just takes all the guess work out of it
Old Mar 11, 2004 | 06:55 PM
No its just that every 03 i race these dayz I LOOZE!!!
So i fugure evryone name is like supra killer , 03cobra killer,Enzo killer, BUt im a little more factual and differnt
Old Mar 15, 2004 | 02:30 PM
Banshee's Avatar
Originally Posted by BigPlanTransAm
its really just a smaller exhaust housing for the turbo, the problem is the R&D to find out which is the best one for you.
they've already done all the research so why not buy it from them?
what is the .ca for? is he in Cali? i would rather get it from an east coast dealer unless he would do free shipping. and anyway im in no hurry, if he doesnt want my buisness ill just keep sprayin
The turbo is no problem
but the guys at STS dont want to tell me what kind of elektric olipump
they are using
maby they cant understand my english *lol*
can someone please help me where i can buy that oilpump
the dealers in sweden never head about of a pump like that..
Old Mar 15, 2004 | 02:37 PM
they probably dont tell you not because they dont understand the question but because they want you to buy the kit from them cant blame them for trying though. if you dont find it maybe you could order just the pump.
Old Mar 15, 2004 | 02:48 PM
  #32
Banshee's Avatar
if you dont find it maybe you could order just the pump.>>YES!! but where can i buy it??....price?...
Old Mar 16, 2004 | 07:44 PM
  #33
Its a scavenge pump i believe !!
Old Mar 17, 2004 | 02:35 PM
  #34
im saying maybe you could call STS and order just the pump from them.
Old Mar 17, 2004 | 04:14 PM
  #35
trtturbo's Avatar
By the time someone went through all the trail and error they would have spent as much as the kit costs. I sell the STS kit and there is alot more to it than just getting pipe bent and slapping it on. The kit has a EGR switch valve so that under boost you are not pumping boost into the crankcase. There is the wiring to consider; it has to be set up to run the oil pump, which is a 2 speed pump. All the charge pipe is mandrel bent and coated inside and out. In most cases, it is more cost effective to by the kit instead of the trail and error method.
My car is stock except for LS6 springs and a ported throttle body and at 5psi it makes 412/451; I got 29.7 mpg highway and the car drives just like it always has until you get on it. Anyone with questions, feel free to call me at
817-703-3750
Billy
Old Mar 17, 2004 | 05:20 PM
  #36
Banshee's Avatar
a 1000 thanks..
*happy*
Old Mar 17, 2004 | 05:26 PM
  #37
Banshee's Avatar
817-703-3750
Billy
there is alot more to it than just getting pipe bent and slapping it on >>yeah? but what?.... alot of things??
you just want to sell the kit
Old Mar 17, 2004 | 05:54 PM
  #38
White_Hawk's Avatar
My car is stock except for LS6 springs and a ported throttle body and at 5psi it makes 412/451; Billy
Been to the track yet?
-Geoff
Old Mar 18, 2004 | 05:48 AM
  #39
trtturbo, where are you located?
Old Mar 18, 2004 | 12:26 PM
  #40
trtturbo's Avatar
I have not been to the track yet, but will try this weekend. My car an '02 Formula, 6speed, stock GS-C's, I'm not sure what to expect, but I am hoping for low 12's.
I am located in Mansfield Texas.
As far some of the other things to consider if you are wanting to build it yourself;
The oiling system/ scavenging pump is a 2 speed pump. The pump runs on low until you hit 1psi, then goes to high. You have to have a switch for that and be able to wire it up. I know alot of you can do this, but there are alot more who cannot. The oiling system is also set up so that if there is a back up of pressure that hits 3psi, meaning there is a problem with your oil return there is an buzzer that goes off. As I mentioned before, there is a switch valve so that under boost you are not pumping boost through the pcv system.
The systems are well thought out and when you compare it to other systems, they are well worth the money.
I will be installing a system on a T.A. with some mods and lower compression and will be running about 9psi. We changed the housing so he will be able to carry boost past 6000rpms.
