STS updates?
Old Feb 12, 2004 | 10:28 PM
Drake's Avatar
Default STS updates?
Anybody hear from Rick lately? Better yet, anyone get a kit yet?
Old Feb 12, 2004 | 11:59 PM
frcefed98's Avatar
Here is an email I got from him a few days back.....
"LS1 systems will be available later in the month. I've been real busy and
have turned marketing/website over to our marketing guys. We installed 2
LS1 systems about a week ago. One dyno'd almost exactly what our prototype
did. That car drove up from Texas for install. Another drove up from Vegas
and had one put on. He will be getting tuned and dyno this week I believe.
The one on my 98 runs great, haven't dyno'd yet though. All the LT1 cars
are running great.
This will be a good year for us.
Later, Rick"
So who in Texas got one? Speak up.
J
Old Feb 13, 2004 | 03:20 AM
DarkblueTA's Avatar
Kane is the guy in Vegas that has one. He dyno'd today but I havent heard any numbers yet.
He and I are having a Turbo vs Procharger 'battle' T60 Vs P1SC
Its going to be fun
Old Feb 13, 2004 | 09:39 AM
Drake's Avatar
Its going to be fun
Great! Do keep us updated...
Old Feb 14, 2004 | 07:24 PM
DarkblueTA's Avatar
STS Turbo kit. Kanes care 2000 Z28 M6 Spec stage 3 clutch and stock 10 bolt with 342 gears. Not sure what else, but if anything its small. Anyways, I was told he put down......
5# = 430rwhp
8# + injection = 470rwhp
NOTE: Don't quote me, this is what I heard from a 3rd party. Also this dyno, from what I'm told by everyone here that the dyno rates low as low as 30rwhp........take it with a grain of salt.
he did run a 12.9@115mph...spinning in 1st and 2nd but I don't know if he was on his 5# or 8#...I assume 5#
Old Feb 15, 2004 | 12:15 AM
CHRISPY's Avatar
Those numbers arent bad at all I bet with tuning and proper fuel system it would do better.
Cheers,
Chris
Old Feb 15, 2004 | 01:03 AM
MYTURBOT/A's Avatar
Thats the problem with the 60mm turbo that comes with the kit he`s about maxed at what that turbo will support (500 rwhp) So to make more power he`ll have to go to a bigger turbo or up the boost and run it way out of it`s efficency range. Very impressed with the numbers though. Glad this kit is working out it`s going to be a nice option for the guys that need to pass emissions but still want to go FI. So much for all the nay sayers on here this (poor design) turbo kit is making more power then my traditional design turbo kit. Good job STS.
Old Feb 15, 2004 | 03:12 AM
2edybrd's Avatar
That the kit can support upto 5-600 bhp is fine for me. I don't need to be a drag strip/ street racing terror. I just want to keep my perma-grin up and running.
Besides, five hundred at the wheels WILL hand most cars there ***. And if it doesn't. Oh well, I wouldn't be too broke up about that.
Old Feb 15, 2004 | 09:12 AM
sr71bb's Avatar
Just went to Autorama in Dallas and they had a vendor there that sells and installs the STS kit. His company was Texas Rear Turbos out of Mansfield Texas (Billy May - 817-703-3750). He has his SOM 2002 Firebird there with the kit standard installed on it (4-5 PSI).
He said the 4-5 PSI kit on an absolutely stock motor (stock injectors, no tuning etc.) makes around 420HP and 450 TQ. The cost on this kit is around $3,700.00 and Billy said they get around $300.00 more for the installation which takes 2-3 hours.
They have an alky injection option which is run when you upgrade to 7-8 PSI.
I believe in this case they use the same turbo. I am not sure EXACTLY what the upcharge is for this option.
The install looked pretty clean and my only concern might be ground clearance issues at times if you had a lowered car. There is a pipe hangs fairly low that is around the driver's side rear wheel. I don't think it will be a problem with a standard height car but LOWBIES maight have to be careful.
Boost apparently starts around 3000RPM. ON a side note, there were quite a few curious on-lookers and Billy mentioned he had been getting that all day.
Old Mar 7, 2004 | 12:45 PM
Banshee's Avatar
Default Sts??
I don´t understand how the oil returns from the Turbo charger back to the engine?
is there a separate oil system or what?
don't get it???
Old Mar 7, 2004 | 01:53 PM
BigPlanTransAm's Avatar
yes, it has its own pump.
as for getting kits, i e-mailed them a few times in the past couple of weeks in hopes of buying one and got no response whatsoever
Old Mar 7, 2004 | 02:06 PM
JoeDirt's Avatar
Try contacting Roy @ sales@canadianhighperformance.ca . Hes in the loop and is a sts dealer .
Old Mar 7, 2004 | 10:00 PM
j4nash's Avatar
Has anyone used a sts turbo system on a truck
Old Mar 7, 2004 | 10:46 PM
CAT3's Avatar
Restricted User
Someone has, or there wouldnt be pics of it on their site. It seems hard to find ppl using any of the kits out there lately. I only had one response on users of the QMP kit, other than Rob. And there are a few with TT street kit from the first batch mostly.
DarkBlueTA-With the Dyno #'s above, is this a high altitude or what? Alwasy see ppl making low numbers in high elevation, thought the dyno corrected for that, but not all ppl get the corrected #'s. Interesting to say the least.
Old Mar 8, 2004 | 03:08 AM
DarkblueTA's Avatar
They dyno numbers were in Las Vegas NV. about 2200-2300 feet. I'm assuming that they are corrected though.
Old Mar 8, 2004 | 09:58 AM
Banshee's Avatar
What kind of pump?
as soon as i figure it out im gonna build the kit myself
anyone got some ideas how to make a pump like that??
Old Mar 8, 2004 | 10:56 AM
j4nash's Avatar
How is this kit going to hold up over the years?
Are the fittings going to come loose and fall off?
Old Mar 8, 2004 | 11:07 AM
rons 00z's Avatar
he uses a special turbo designed for his kit to reduce lag so you'll need one of those too.
Originally Posted by Banshee
What kind of pump?
Old Mar 8, 2004 | 09:36 PM
its really just a smaller exhaust housing for the turbo, the problem is the R&D to find out which is the best one for you.
they've already done all the research so why not buy it from them?
what is the .ca for? is he in Cali? i would rather get it from an east coast dealer unless he would do free shipping. and anyway im in no hurry, if he doesnt want my buisness ill just keep sprayin
Old Mar 8, 2004 | 09:47 PM
02BlueFirehawk's Avatar
.ca is canada... thus canadianhighperformance.ca
