Procharger belt problems HELP!!!!!!!!!!
Old Feb 9, 2011 | 05:09 PM
mp_ranger's Avatar
Default Procharger belt problems HELP!!!!!!!!!!
ok first of all thank you for reading second I have a 00 Firehawk with a P1 procharger. When the blower was installed the belt would squeal. two days ago i changed the oil and noticed the belt was incredibly frayed. I bought a new belt took the whole thing out put back and i noticed today its beginning to fray again. What the hell is wrong it doesnt seem to be hitting anything any info would be greatly appreciated
Old Feb 9, 2011 | 05:41 PM
BadgeZ28's Avatar
Where is the damage on the belt? If it is on an edge could be an alignment problem. The crank pulley and supercharger pulley must be parallel and aligned. Slipping usually results in belt dust around the pulleys.
Old Feb 9, 2011 | 05:52 PM
MadIceV8's Avatar
Customizing Director
Sounds like it's getting caught on something or isn't aligned good enough.
Old Feb 9, 2011 | 05:57 PM
mp_ranger's Avatar
yeah the belt is damaged from the edges how would one know if the blower is aligned correctly? thanks guys for the response
Old Feb 9, 2011 | 07:36 PM
slolt1's Avatar
Check the idler or tensioned pulley mine was doing the same thing bearing had ant out
O
Old Feb 9, 2011 | 09:20 PM
mp_ranger's Avatar
i was looking at the tensioner pulley from the mount on the procharger and it looks like it may be installed wrong. it looks like there is a lip on the opposite end of the pulley that may prevent the belt from rubbing on the bracket. I will need to look at it but its gonna be awhile until i do. Can that pulley be installed backward?????
Old Feb 10, 2011 | 09:16 AM
Aster's Avatar
Which side of the belt is most frayed? Is the head unit pulley properly spaced out?
Old Feb 10, 2011 | 01:43 PM
mp_ranger's Avatar
the side closest to the bracket is frayed it was installed by a friend so I have no idea how to check if it is spaced properly if you guys know how I can try to see if it is
Old Feb 10, 2011 | 02:33 PM
Aster's Avatar
You can usually tell when looking down at the blower in between the pulley and the head unit if the shims are in place. Especially since the edge of the head unit pulley would be very close to the face of the bracket.
Old Feb 10, 2011 | 06:45 PM
WHPLASH's Avatar
I did this a couple times, I forgot to retighten the idler pulley. Then, I would keep tightening the tensioner down due to slipping and then pop. No more belt.
Old Feb 11, 2011 | 11:13 AM
b727pic's Avatar
I fought with pulley alignment issues with the original install on my GTO. tried straight edges, laser sights, all kinds of issues. Mine wanted to walk off the front, ie away from the blower. What finally solved it was this procedure:
I backed off the blower pulley bolt several turns...approx .250. Start the car and let it idle, the pulley found its center, I was able to actually see the pulley had moved while the engine was running. With the engine shut down, I measured the gap between the pulley and blower, shimmed accordingly, torqued the pulley bolt, done....that solved all of my belt alignment issues.
Old Feb 12, 2011 | 09:37 PM
Bob@BruteSpeed's Avatar
LS1Tech Sponsor
Active Streak: 30 Days
Active Streak: 60 Days
Thumbs up
Ron, that's a great way to see how the belt is tracking. Bob
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
Old Feb 13, 2011 | 11:35 AM
ChevyChad's Avatar
8 sec potential, 12 sec slip
I was thinking the same!
Old Feb 13, 2011 | 06:14 PM
b727pic's Avatar
Thanks guys....one caveat on this procedure. You have to make sure your pulley moves fairly easily on the blower shaft. I used a little bit of anti seize which works great.
Obviously with safety in mind, this is an Idle only procedure..
