pt-88 housing ?
Old Feb 11, 2011 | 04:20 PM
yessir's Avatar
Default pt-88 housing ?
has anyone used the on center housing on the pt-88. If not any *KNOWLEDGE*(dont want to waste $1500 on an educated guess) on the on-center housing vs the tangential would be greatle apreciated. the turbo will be going on a stock cube lq9 with a mild cam.??
Old Feb 11, 2011 | 04:56 PM
Shawn @ VA Speed's Avatar
on center housings never work well. Go with the tang housing.
Old Feb 11, 2011 | 05:21 PM
black98ws6ta's Avatar
On-centers suck basically.
Old Feb 11, 2011 | 06:45 PM
yessir's Avatar
problem is .......no space. When you say they never work well what exactly do you mean,,,, poor spool? backpressure?
Old Feb 11, 2011 | 09:04 PM
TheBlackPlague's Avatar
Somewhere a while back I saw an article, which I could round it up, but I swear it said 15% loss from on center vs tang. But in a space type situation, where no other option is available, a turbo with an on center is better then none at all right? Lol
Old Feb 12, 2011 | 11:18 PM
yessir's Avatar
hmmmmm. is there anything that can be dont to an on center housing to make it more efficient. At a 15 percent loss in efficiency wouldn the pt88 now perform something line a 76gts with a **** ton more lag???
