Alky kit
Old Feb 14, 2011 | 12:12 PM
Frametwista's Avatar
Exclamation Alky kit
Is it absolutely necessary that you have to get a new dynotune or tune period when you throw a alchohol kit on your car.My tune is super conservative and a little rich im only running 6.5lbs of boost i want to put a alchohol kit on the car and just up the boost to about 8or 9lbs can i do this safely without having to change the tune?thx n advance
Old Feb 14, 2011 | 12:42 PM
Anybody?
Old Feb 14, 2011 | 04:18 PM
BigRich954RR's Avatar
you can added the kit with out a tune if you keep the psi the same if you up the psi retune and dont let it run to rich with out the meth so its only a little rich with meth.
Old Feb 14, 2011 | 05:22 PM
MUSTANGBRKR02's Avatar
Yes you need a retune. You will be way to rich if you do not. Your VE table on meth will look like it fell off of a cliff. You can also push more timing.
Old Feb 14, 2011 | 05:55 PM
XtremeDime's Avatar
I ran 8psi on pump gas(91 oct here) with no problems. I wouldnt really worry about a meth kit until you run more boost IMO
