typical cost of turbo charging?
Old Feb 16, 2011 | 01:08 AM
firechicken76's Avatar
Default typical cost of turbo charging?
just wondering about how much i could expect to put down on doing a turbo build on an ls1, its an 02 in an 88 trans am, ive got an aftermarket fuel pump, 60 pound injectors, and a forced induction cam, also running a stock ls6 intake with a ported tb.
Old Feb 16, 2011 | 02:17 AM
TurboAv's Avatar
Your end goal will dictate the cost of the turbo parts and supporting mods. So it varies. $5k-$30k.
Old Feb 16, 2011 | 03:25 AM
XtremeDime's Avatar
If you are not concerned with preventative parts like an oil pump, transmission, converter(or clutch), rear end, driveshaft, valvesprings, pushrods, etc. Then it can be done rather cheaply.
Of the list I would recommend an oil pump, valvesprings, and pushrods initially. You can replace the tranny and rear end when they break(they will after a while). If you keep the boost low 6-8psi you should be ok for a while, atleast I was
Old Feb 16, 2011 | 03:51 AM
BottleFedZ346's Avatar
If you have a set budget think double of that!
In the end it all depends on your power goals......
Old Feb 16, 2011 | 07:14 AM
505OUTLAWZWS6's Avatar
I had less than 1800 in my turbo kit alone on my first build. $1200 into my fuel system, and now after a larger turbo, I am about $3000 in the hole.
Old Feb 16, 2011 | 11:10 AM
smokinHawk's Avatar
https://ls1tech.com/forums/forced-in...induction.html
