procharger/ Head Help?????
Old Feb 16, 2011 | 03:04 AM
TheZDeWolfe's Avatar
Default procharger/ Head Help?????
Alright guys i got a full dsc1 8 rib dual 4.5 intercooler kit for my Z. although its stock bottom end. I was looking into 317 heads for mine. Is Cnc' needed on them heads to make good power????? I just wanna get into the mid 5's!!
I will invest in a alky kit as the spring comes. but just want to know your guys opinion on whether or not them 317 heads flow good as they are or def. need to be reworked to get me to the 5 range!!! any sugestions??
Old Feb 16, 2011 | 07:24 AM
Bob@BruteSpeed's Avatar
LS1Tech Sponsor
Active Streak: 30 Days
Active Streak: 60 Days
The 317 heads are not going to give you more power unless you get them cnc'd. You would actually lose power with stock 317 heads do to the loss in compression. You might want to consider leaving the heads alone and adding a performance camshaft, as you'll get more power from a camshaft upgrade. Bob
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
Old Feb 16, 2011 | 10:26 AM
LS1RedZ's Avatar
Mid 5's?
Old Feb 16, 2011 | 12:23 PM
Okay so your thinking leave the stock ls1 heads and i plan on doing a cam swap and doing the dual valve spring upgrade also. but you can see mid 500 horsepower outta these ls1 heads??? Thanks for the help.
Old Feb 16, 2011 | 12:27 PM
Also dont i want to drop compression to run higher boost levels off the procharger or do i got this all wrong?? My plan is to run 8 psi till i get the alky system and start finding a 6.0 block and forging it all. Also i do have a bigger pump and 60 pound injectors big red race valve. also will be going ls6 intake with ported tb soon. to give you a idea what im working with.
Old Feb 16, 2011 | 01:04 PM
LS1RedZ's Avatar
I thought you were talking about ET wise lol. Heres my sign! haha
Old Feb 16, 2011 | 01:29 PM
Hahaha oh yeah horsepower ways!! 5's et!!! I wish!!
Old Feb 16, 2011 | 01:47 PM
hatcher1986's Avatar
I thought the same thing.. I didn't wana break the bad news to him.. Lol. Should make around your HP goals tho.
Old Feb 16, 2011 | 01:50 PM
youngrigo's Avatar
I made 523rwhp with the stock heads (241) and a 02+LS6 cam on 9psi
Old Feb 16, 2011 | 01:58 PM
Awesome! That's what I wanted to hear! I just don't wanna invest a lot of money into these heads but maybe I'll just do dual spring kit on them.
Old Feb 16, 2011 | 05:32 PM
Monte4ever's Avatar
As far as compression, most recommend 9.5 to 10.0. This gives you decent bottom end torque until the blower takes over.
Old Feb 16, 2011 | 05:41 PM
02LS1ram's Avatar
I made 533whp on a very conservative tune with a P1 headunit. I would look into the brute speed blower cam. Sounds nasty and makes good power!
Old Feb 16, 2011 | 09:47 PM
blue00ZZleeper's Avatar
I'd leave the heads, run meth and a good cam.
Old Feb 17, 2011 | 02:43 AM
Okay. Glad you guys cleared that up for me. blue00zzleeper how much boost you run on your old setup with the stock bottom end? i seen them are some pretty impressive numbers! And also ill check into the brute speed cam!
Old Feb 17, 2011 | 06:15 AM
LS1Tech Sponsor
http://shop.brutespeed.com/Comp-Brut...n-Camshaft.htm
Thanks, here is a link to it. I'll bet you'll pick up 60 or so rwhp with this camshaft. Bob
__________________
Old Feb 17, 2011 | 11:41 PM
It was around 10psi with the 317 heads and methanol. 10psi and 17 or 18*. I have the 317's If your interested but honestly I'd run the stock heads if your only looking to run 10psi or less. The larger CC heads just help against detonation. She ran like a champ...I miss driving her lol
Old Feb 18, 2011 | 01:55 AM
Thanks Bob. I will be buying the whole cam and everything from you when the time comes! Blue00zzleeper sounds like a beast im hoping to work my way into something you had!!
Old Feb 18, 2011 | 05:07 AM
LS1Tech Sponsor
Thumbs up
Thanks, I appreciate it! Bob
__________________
Old Feb 19, 2011 | 02:51 AM
Okay but now whats your thought of esp blower cam? Is it the same thing or whats your opinion on that Bob? just bouncing it off ya!
Old Feb 20, 2011 | 05:32 AM
LS1Tech Sponsor
Question
I'm not familiar with an esp blower cam, what are the spec's on it? Thanks. Bob
__________________
