150k dd
Old Feb 16, 2011 | 10:55 AM
cory32690's Avatar
Default 150k dd
150k 01 formula a4 car runs great just been looking and cam swaps but was thinking I've seen some people on here diy for just a little more than a cam swap
The big question is I want to no if I should even be considering turbocharging this car that I daily drive that ha 150k on stock long block
Old Feb 16, 2011 | 11:06 AM
SPRAYED 01's Avatar
You will be at least 3 times higher than a cam swap for doing a proper turbo kit even if you do it all your self. Not to mention you have a tired engine. start with a cam. Then save up for a motor and turbo kit
Old Feb 16, 2011 | 11:22 AM
cory32690's Avatar
Do u think a cam swap at this many miles will be ok..
Old Feb 16, 2011 | 12:45 PM
TTLS1GP's Avatar
the engines themselves are good for well beyond 120k. I'm with SRAYED...You could always put a cam in and enjoy that until you want to rebuild and turbo.
Old Feb 16, 2011 | 01:47 PM
cory32690's Avatar
I would think putting a cam in would be harder on the motor just because any of the cams I like spin well past 6500and the body end would come apart quicker than 5lbs of boost from a turbo
Old Feb 16, 2011 | 01:49 PM
cory32690's Avatar
If I was to leave a stock came in it on low boost I wouldn't have to spin the motor past 6200
