maf vs map
Old Feb 20, 2011 | 07:06 AM
4doortypels's Avatar
Default maf vs map
so im going to turbo a ctsv, against all odds, ill make it work. so when i get this thing tuned... whats the best tune type you go with... i was wondering if i should upgrade to an ls3 cartridge style maf or stick with the stock ls2 maf... or can you go to a full out MAP sensor, as they have both. or in the tuning just go with a speed density tune... i dont know a ton on tuning, but just wanted a little more in GM world. any input would be appreciated
Old Feb 23, 2011 | 01:27 PM
anyone wanna shed a little light
Old Feb 23, 2011 | 01:38 PM
b00sted's Avatar
I know the problem with GM MAF's has always been that they output frequency instead of voltage...So they max out easily and there's no way that I know of to extend the signal. In the Ford world, the MAF's output voltage for their signal, and it's easy to extend their range and make big power(900+ rwhp with a Lightning MAF).
I don't know about the LS3 MAF at all, but I'm assuming it's in the same boat as the previous models.
That being said, a speed density tune with a 3-bar MAP will likely be easier and more reliable to make power with. You can get away with the MAF in a blow-through configuration if you're not looking to make too much power. I'm sure the pro LS1 tuners on here can shed some light.
Old Feb 23, 2011 | 05:01 PM
slow67's Avatar
Gingervitis Addict
The other problem is the MAF table runs out of fuel (values maxed out) without scaling anything (PITA!).
Old Feb 23, 2011 | 08:17 PM
4SFEDSS's Avatar
I would go speed density, but you really need to consult with the person who your going to have tune it to find out what they're comfortable with.
