Where to plumb boost reference line from Procharger
Old Feb 20, 2011 | 10:51 AM
wreckwriter's Avatar
Question Where to plumb boost reference line from Procharger
hey guys, just finishing up my new dual pump fuel system. Last thing to do is hook up the boost reference line to the regulator. what's the best place and method to get boost reference on a ProCharged system? Would prefer not to drill and tap the metal tubing but looks like that might be the only option.
thanks!
Old Feb 20, 2011 | 01:28 PM
WhistlingZ's Avatar
Don't you have any vacuum lines you could tap into?
Old Feb 20, 2011 | 01:33 PM
I was told that it needs to see boost only, not vacuum.
Old Feb 20, 2011 | 02:11 PM
Ericmck2000's Avatar
put a one way thinge in the line.
Old Feb 20, 2011 | 02:26 PM
That's a good idea. Thanks!
Old Feb 20, 2011 | 05:10 PM
NemeSS's Avatar
What's a one way thingy?
You mean one way check valve?
Old Feb 21, 2011 | 07:22 PM
Lonnies Performance's Avatar
LS1TECH Sponsor
A check valve will not work properly..... it will hold pressure as well.
On the G8, you cannot run below 58# due to the fuel transfer function.
For boost reference (positive pressure only), anywhere in front of the throttle body, preferrably as close as possible to it to get an accurate pressure.
Old Feb 21, 2011 | 08:58 PM
OK, I guess my only option is to drill and tap the metal elbow. I wish there was a better way to get it; I don't trust NPT threads in such thin metal.
Old Feb 22, 2011 | 08:10 PM
Pocket's Avatar
Weld a bung that has a bit more substance to thread
Old Feb 23, 2011 | 01:02 PM
Good idea. Thanks!
Old Feb 23, 2011 | 05:09 PM
98Z28CobraKiller's Avatar
Restricted User
This is a G8 only thing, right? I have never seen a BRFPR hooked up to anything other than the intake.
Old Feb 23, 2011 | 06:39 PM
LS1TECH Sponsor
Typically anything with a fuel transfer system... such as all C5 & C6 Vettes, G8's, 2010 Camaros etc. These need a minimum pressure to keep the transfer system working. Typically 58psi is the minimum pressure to maintain. Boost reference is OK, but the drop due to vacuum can cause problems.
Old Feb 23, 2011 | 06:57 PM
Monte4ever's Avatar
Do the other systems with a blower run at a constant 58-60 PSI without boost reference and then tuned through the computer, OR is a boost reference regulator absolutely necessary?
Old Feb 24, 2011 | 03:16 PM
LS1TECH Sponsor
Boost referencing is not necessary, but it extends the usable range of the injectors by keeping fuel pressure linear with manifold pressure.
Old Feb 24, 2011 | 04:36 PM
Monte4ever's Avatar
So would it be ideal to run it if you have it? I'm asking because I was just going to set the pressure at a steady 58-60 and leave it. But if it would run more efficiently with it I'll hook it up. Just trying to get everything right before I fire it up. By the way, this is a retro fit setup in a 82 Monte Carlo with a Magna fuel 750 fuel pump.
Old Feb 24, 2011 | 09:51 PM
LS1TECH Sponsor
I always boost reference when possible.
