9.81@145
Old 02-21-2011 | 06:04 PM
Clean94Z's Avatar
Originally Posted by Hank Peabody
Nice setup! Did you make 750whp setup like this? My car went 145mph at around 3300# so that is very interesting. What was the DA that day if you know? Thanks
He made 753whp@16psi and ran a 10.3@142.9. No dyno numbers for 18psi.
CONGRATS DUDEMAN!!!!
He and his friend kevin built this car in his garage. Motor,trans,rearend,cage everything!!! UNDERDOGS FTW!!!
Old 02-21-2011 | 08:08 PM
dudeman's Avatar
true story! on the 10.3 pass i left on no boost and had a 2.0 60ft lol
Old 02-21-2011 | 10:20 PM
overhere's Avatar
very nice! what was your launch rpm?
Old 02-21-2011 | 10:32 PM
dudeman's Avatar
about 3300
Old 02-21-2011 | 10:33 PM
overhere's Avatar
is the 2-3 psi all it would make? or did you have it set low?
Old 02-21-2011 | 11:09 PM
dudeman's Avatar
my suspension needs to be dialed in. i knew that between that and the track it wouldnt take much more boost on thelaunch. the most i have seen it make on the brake is around 10psi. i was about 30-40% on the brake.
Old 02-22-2011 | 12:52 AM
Unstang's Avatar
Congrats on the 9 on the first time out with it.
Do you mind sharing your suspension set up?
Old 02-22-2011 | 12:54 PM
dudeman's Avatar
lakewood lift bars
upr double adj uppers
upr anti roll bar
lakewood 90/10s and 50/50s
coilovers all the way around
front is to stiff. i need more travel
Old 02-22-2011 | 04:58 PM
ReApEr75's Avatar
So much win. Awsome run for the first time out.
Quick Reply: 9.81@145
