Tu1 cam?
Old Feb 21, 2011 | 07:13 PM
70c10's Avatar
Default Tu1 cam?
I'm looking for a turbo cam and I was looking at the speed inc tu1 cam. It says it has a 113 lsa. From what I read a cam with a higher lsa is better for boost. Will this cam bleed off boost and cause my turbo to take longer to spool up. I would like the idle to be choppy and I know choppy isnt good for boost so if this is a good cam for my setup and is a little choppy it would be perfect for what I want. It is a street only truck maybe the track a couple of times a year. would you reccomend a different cam? my setup is
2001 stock ls1 bottom end
mp t70 .96ar turbo
c6 flipped maniflods
2.5" cross over
3"dp
50mm gate and 60mm bov
Old Feb 21, 2011 | 07:30 PM
MUSTANGBRKR02's Avatar
It will be fine. I have two 370 cars with this cam.
Old Feb 21, 2011 | 08:19 PM
willizm's Avatar
I picked this cam up for my build. Haven't installed it yet, but I've heard good things about it.
Old Feb 21, 2011 | 08:24 PM
70c10's Avatar
is the idle choppy?
Old Feb 21, 2011 | 08:31 PM
Sort of.
Old Feb 21, 2011 | 08:56 PM
yessir's Avatar
mustangbrk.....what c.i. are your motors what turbos and what rpm do those cams peak at?
Old Feb 21, 2011 | 10:16 PM
ls1_chevelle's Avatar
I've been running one of these for 2 summers now. Works well.
Here is an accient sound clip when the car had a 76mm on it.
http://www.youtube.com/watch?v=0gZ6hTZwSI8
Old Feb 22, 2011 | 01:56 PM
itsjustaSB's Avatar
man thats choppier than i though but ur exhaust probly has alot to do with that to i have the tu2 grind kinda whish i woulda went with the tu1 now i havnt ran the car yet but i thenk its going to be alittle to much but oh well it will work well when i put the 90mm on
Old Feb 22, 2011 | 02:56 PM
I'll trade you for my TU1. it has 700 break in miles on it.
Old Feb 22, 2011 | 03:19 PM
stock48's Avatar
9 Second Truck Club
mp t70 .96ar turbo
2.5" cross over
3"dp
There is nothing wrong with the tighter lsa in my book. Im running a 112lsa and it's just as strong or stronger than the same grind 114lsa that was in my other lq4.
Old Feb 22, 2011 | 03:48 PM
Hank Peabody's Avatar
You've also shown a relatively tiny cam can make a ton of power, your little cam is the reason I have a 216/216, pure success power wise.
Old Mar 1, 2011 | 06:05 PM
SStolen's Avatar
That sound isn't what I was expecting. I was wanting a cam with a little faster lope than that. Going with a Precision 76GTS on a flipped manifold set-up/365ci LS2. Any suggestions?
Old Nov 4, 2013 | 10:53 AM
SuperC1's Avatar
Back from the dead, thats a lot of chop for such a small cam. I like..
