PCV Delete Questions
Old Feb 21, 2011 | 10:06 PM
Adam86's Avatar
Default PCV Delete Questions
I have my PCV delete in progress and had a few questions before I finished. Here is what the system looks like.
Uploaded with ImageShack.us
I will have two -6AN fittings at the back of each valve cover with hose connecting them to even out pressure.
Another 2 -6AN fittings at the front of the valve covers with hoses running to a vented catch can.
I also have a breather filter on my oil cap. I will be capping off all other unused ports involving the PCV system.
Will this work alright? It is for an FI application but I will be breaking in the motor about 1000 miles before I put the turbo on. Will this be okay for my motor while it's still NA?
Don't know if you need the info but it will be running 9.4:1 compression while NA and will later see 8-10psi of boost. Will this be sufficient to vent the crankcase? Thanks guys!
Old Feb 22, 2011 | 07:54 AM
Old Geezer's Avatar
W/ the fill vented, the pressure will just take the path of least resistance..Could be thru the can, or more likely the fill breather....
Old Feb 22, 2011 | 10:36 PM
Adam86's Avatar
Thanks man! I figure there's no harm in having as much crankcase relief as possible. If I get a lot of oil spraying out of the filler filter I'll probably just take it off.
