Procharger PCV Solution Needed
Old Feb 23, 2011 | 08:40 PM
tatasta's Avatar
Default Procharger PCV Solution Needed
Hello,
I recently put a P1SC in my 99 T/A running @ ~ 7-8 lbs. I really did not have a good PCV/catch can setup in use when I first ran it. I think I may have pushed the rear main seal a bit. If so, I will fix it.
In the mean time, I want to get the proper ventilation set up prior to running again.
At this point, all I have done is the vent on the pass side valve cover is routed to the inlet hat port and I have a breather (in pic) in the oil fill hole.
What is recommended to avoid further problems with excessive crankcase pressure?
By the way I have an LS1 valley cover.
Thanks
Old Feb 24, 2011 | 05:35 AM
Bob@BruteSpeed's Avatar
LS1Tech Sponsor
Active Streak: 30 Days
Active Streak: 60 Days
Originally Posted by tatasta
Hello,
Thanks
Your combination with using the Caspers valve cover breather should be all you for no more boost than you are producing. Bob
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
Old Feb 24, 2011 | 03:58 PM
tatasta's Avatar
Thanks Bob. One last question. I have read that it is not a great idea to run a hose from my pass side valve cover to the inlet hat because of the oil being pulled into the head unit. It makes sense but, how big of a concern is it and is there a better way?
Thank you
Bob
Old Feb 25, 2011 | 08:36 PM
tatasta's Avatar
ttt...
Old Feb 25, 2011 | 11:05 PM
RaVagE's Avatar
Not sure if you have seen this, but its very helpful
https://ls1tech.com/forums/11059703-post70.html
Old Feb 26, 2011 | 07:35 AM
tatasta's Avatar
Thanks! That is, by far, the most helpful info on PCV/catch can setup I have seen.
