Looking for build advice...turbo, cam, etc
I also want it to be streetable, driving it to work in the city when its nice out. yet make a lot of power. High 8s, low 9s in a sorted out chassis.
Im guessing I could pull this off with a truck manifold kit, 2.5" crossover pipes, to an 88mm turbo? Could I get away with something smaller?
Point me in the right direction please!!!
Anyone have a cam recommendation? Looks like a lot of you guys like the TU1. Would that be a good matchup, or am I getting out of its working range?
making to power to do it is not the hard part, but making the suspension/weight/safety ect........ is where its going to kill your dream
im not saying its not possible but it will cost way more then you think to have a 8sec street car
And op, unless you're adding weight intentionally, you will be WAAAY under 3300#'s!! My old notch was 2750 with me in it with an ls1/6spd full interior, all power options and stock sn-95 brake conversion! A little weight was removed but no cutting, just poly seats, drag rims, no a/c sorta thing. I know 2 guys on here with lsx turbo mustangs, and the one that is a hatch with a 408 iron motor/80mm combo is 2750 without him in it and ran 8.60's with an ebay fmic to boot! Looking for 8.30's this year! This is with e'85 but i'm guessing you're looking at running race fuel anyway at the strip so you should have no problem getting a high 8 at least out of the car once sorted out.
And for another comparison, MightyMouse is about 3600rw with that gt88 and went mid 8's last year and just upped to the gt91 so bottom 8's may be in order this year!
Bottom line is it can be done with the right parts. Making the power wont be the hard part, even with truck manifolds. Your #1 issue will be getting the susp/chassis to work. I would recommend MWC...Midwest Chassis to help you out with that since they're local as well. If you have the budget, it's very doable!!
