Which intercooler? Top or cross flow?
I dont want to spend a ton, but if anyone else has any leads on a good efficient intercooler besides these ebay ones that would be great.
2 different styles here......
Which would be better? Overall 31x12x4 cross flow- 4" thick Advertised 800cfm
Or would this one be more efficient/effective? Over all - 24x13x3.5 it is only 3.5" thick but the top flow area has quite a bit more area. advertised 700cfm
How accurate it the cfm rating on these?
it would be more effienct if the outlets were opposite of each other, same with the cross flow.
i have the cross flow one, but cut off one end cap and flipped it, then welded a 4" outlet to it.
The horizontal flow configuration shown above forces the charge air to flow through very few internal intercooler passages. In addition, each internal passage is very long, causing further restriction to charge air flow - resulting in a high pressure drop. In other words, the long route with few passages.
The vertical flow configuration spreads the charge air flow evenly over a far greater number of internal passages and results in significantly less restriction. The path length of each internal passage is also shorter, further improving air flow over a horizontal design. The net effect is a short route with many passages resulting in a massive charge air reduction but with improved air flow.
Why does everyone use the horizontal/crossflow style? I built one for my Nova a few years ago and did the vertical flow style with more passages.
Would the longer passages have a greater cooling effect? I searched some... couldnt find anything.
Another thing I found... the CFM ratings on them??? 800 for the horizontal, 700 for the vertical?? How can that be? or are they just made up numbers? The SQ inches of passages for the horizontal one is 48, and the vertical one 84. So you'd think the vertical one would outflow by far... but they dont list it that way.
Jim
i will probably just get the treadstone though... hoping to find one in the classifids...
used parts are just as good!
[/IMG]
