maxed MAF, options?
Old Mar 3, 2011 | 10:42 AM
kopbait's Avatar
Default maxed MAF, options?
i dropped pulley sizes today and went to tune and my maf freq is maxed out in the upper rpm range. im running around 13psi and i need a suggestion on which one i need to replace it with. im not interested in going to speed density. also, i have the 4inch inlet tube upgrade.
what is the cost difference between a suitable maf and a 2 bar map?
thanks for the help
2001 corvette
d1sc procharger
to much more to list
Old Mar 3, 2011 | 10:47 AM
1lejohn's Avatar
Alot of people are switching to the new style LS3 and 7 MAF's. Sveral companies sell them in a housing ready to bolt on. If you buy one from GM you have to come up with a way to mount it.
Old Mar 3, 2011 | 02:06 PM
02LS1ram's Avatar
I'm also looking for an option on a bigger Maf and have heard about the ls3 Maf but does anyone make a kit. Also how wires is it ?
Old Mar 3, 2011 | 02:14 PM
ChevyChad's Avatar
8 sec potential, 12 sec slip
The limit in your PCM is not really much higher at all than a stock MAF. It is pointless to try and get a MAF that can recognize more flow. You are better off going SD.
Old Mar 3, 2011 | 02:28 PM
barnat's Avatar
Originally Posted by chevychad
the limit in your pcm is not really much higher at all than a stock maf. It is pointless to try and get a maf that can recognize more flow. You are better off going sd.
agreed !
Old Mar 3, 2011 | 09:33 PM
nick y's Avatar
GM also sells the flange...7 bucks...
Old Mar 3, 2011 | 10:21 PM
02LS1ram's Avatar
I have consider goin SD but is there any big advantage to it. My tuner told
Me to switch to the ls3
