another guess HP and ET thread...
Old Mar 4, 2011 | 12:49 PM
driven87's Avatar
Default another guess HP and ET thread...
curious as im new to the ls world what does everyone think this will make at rear wheels and go et wise. 370CI, pt88 t4 flange with 4" DP and electric cutout, stage 3 ported 317's, custom futral turbo cam, forged bottom end, victor junior intake, 90mm nick williams TB, intakeelbows upper,converted mustang headers and custom crossover, 80lb injectors, dual fuel pumps, th350 trans with custom 9.5" PTC convertor, 3.42 rear....this is all controlled with a FAST XFI unit. car will be running right around 20psi/16 degrees timing on meth injection. its all in a 3550lb 87 regal already set up for drag racing with cage and full suspension on slicks. i have heard a few people close to me mention what it should go but im still curious as to what you guys think. reason for asking is im coming up close to getting it done and am getting excited. thanks guys
Old Mar 4, 2011 | 02:26 PM
Ryans99ls1's Avatar
if it doesnt go mid-low 9s something is wrong. i dont see why it shouldnt dip into the 8s either
Old Mar 4, 2011 | 02:55 PM
driven87's Avatar
thats what i have been told that it should dip into 8's and go low low 9's with some ease
Old Mar 4, 2011 | 03:40 PM
MIGHTYMOUSE's Avatar
im betting you have to do more than slap a gasket down to keep from pushing water at 9.0
Old Mar 4, 2011 | 05:25 PM
driven87's Avatar
yeah with the ls9 gaskets and arp studs at 85lbs i know i can only get away so much before gaskets go but thats part of the game....
Old Mar 4, 2011 | 07:46 PM
dudeman's Avatar
who ported the heads and what valves are in them?
Old Mar 4, 2011 | 09:15 PM
driven87's Avatar
they are the stage 3 factory 317 heads on patriotperformance.com...part number 2019
Old Mar 4, 2011 | 10:04 PM
madmax4499's Avatar
10.90 @130, 780 rwhp.
Old Mar 5, 2011 | 04:05 AM
stock48's Avatar
9 Second Truck Club
Depending on how well the engine is sealed up, cam and head flow you could have the power for mid to high 8's but getting it there might take a bit of dialing in.
Old Mar 5, 2011 | 04:59 AM
Nitroused383's Avatar
Pump gas and meth on 20lbs with factory heads?
How much compression?
Old Mar 5, 2011 | 08:42 AM
driven87's Avatar
10.9, lol id smash it into the wall...compression is 9.1:1
Old Mar 5, 2011 | 04:22 PM
98Z28CobraKiller's Avatar
Restricted User
20 psi at that weight should be in the high 8's @ 15X MPH if you can keep water in it.
