truck manifold?
Old Mar 5, 2011 | 04:16 AM
slowblackbird's Avatar
Default truck manifold?
i am getting ready to start getting gathering parts for a turbo build for my 99 ta. i have looked over a ton of build threads but i was wandering if there was a way to run the truck manifolds and keep the alternator in the stock location. the reason behind this is i already have a meziere electric water pump and the bmr alternation for the car and would like to keep that setup if possiable. i have searched just seems like relocating the alternatior is the only way without going to a set of custom headers
Old Mar 5, 2011 | 07:16 AM
MUSTANGBRKR02's Avatar
I believe you can if you cut the flange and weld on a vband.
Old Mar 5, 2011 | 11:34 AM
98blackbirdta's Avatar
I've seen it done a few times, just don't remeber where
Old Mar 5, 2011 | 03:02 PM
Taubr Unit's Avatar
https://ls1tech.com/forums/forced-in...-location.html
https://ls1tech.com/forums/forced-in...manifolds.html
Old Mar 5, 2011 | 04:09 PM
1badWS6's Avatar
Yes you can. You have to cut the flange off and weld a vband clamp so the manifold runs straight forward inse
1badWS6's Avatar
Instead of running downward... damn phone.
Old Mar 5, 2011 | 04:59 PM
That's all I needed to know. Thanks alot for the links, I am sure I will have some more questions I am just trying to start gathering parts and start doing the little things like standing up the radiator and fuel system so I want have to do so much at once. Thanks again!!!
