Twin Turbo Chevy II build
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
Due to some unfortunate circumstances I have to build another car
Some of you already know my silver 64 Chevy II this car is going to basically be a re-body, but with lots of upgrades
My goal for the car is to have a legitimate street car that I can drive to the track and click off some 8 second times (just a goal, reality will set in later) Anyway, here is the car I'm restoring/modifying. You gotta really use some imagination to realize it will actually be a cool car when I'm done putting my treatment to it.
![](http://images5a.snapfish.com/232323232%7Ffp63257%3Enu%3D43%3C%3B%3E%3B45%3E257%3EWSNRCG%3D33435%3A%3B335348nu0mrj)
![](http://images5a.snapfish.com/232323232%7Ffp633%3A7%3Enu%3D43%3C%3B%3E%3B45%3E257%3EWSNRCG%3D33435%3A%3B353348nu0mrj)
First step is to the lift bay for some dismantling
![](http://images5a.snapfish.com/232323232%7Ffp63394%3Enu%3D43%3C%3B%3E%3B45%3E257%3EWSNRCG%3D33435%3A%3B372348nu0mrj)
![](http://images5a.snapfish.com/232323232%7Ffp6325%3B%3Enu%3D43%3C%3B%3E%3B45%3E257%3EWSNRCG%3D33435%3A%3B375348nu0mrj)
![Bomb](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_bomb.gif)
![Winky](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_wink.gif)
Cutting out the stock frame rails and installing some 2x3" mandrel bent rails. I'm going to leave my self room for plenty of tire out back.
![](http://images5a.snapfish.com/232323232%7Ffp6338%3A%3Enu%3D43%3C%3B%3E%3B45%3E257%3EWSNRCG%3D3336798644348nu0mrj)
Setup the rear frame section on my layout table and welded it up before installing in the car.
![](http://images5a.snapfish.com/232323232%7Ffp63268%3Enu%3D43%3C%3B%3E%3B45%3E257%3EWSNRCG%3D333679%3B%3B33348nu0mrj)
![](http://images5a.snapfish.com/232323232%7Ffp633%3A8%3Enu%3D43%3C%3B%3E%3B45%3E257%3EWSNRCG%3D333679%3B56%3B348nu0mrj)
![](http://images5a.snapfish.com/232323232%7Ffp63389%3Enu%3D43%3C%3B%3E%3B45%3E257%3EWSNRCG%3D33435%3A%3B378348nu0mrj)
![](http://images5a.snapfish.com/232323232%7Ffp633%3B4%3Enu%3D43%3C%3B%3E%3B45%3E257%3EWSNRCG%3D333679%3A237348nu0mrj)
Made some front spring pockets that slide up and around the frame rail and crossmember with adjustable holes so I can get the ridehight perfect.
Ok, backhalf is done, time to make some one off subframe connectors. The Chevy II's have a 4 bolt flange that the front subframe bolts to. I bent up some chrome moly and made the connector go from the 4 bolt flange for the front end, down through the factory frame rails, to the front leaf spring pocket on the rear frame.
![](http://images5a.snapfish.com/232323232%7Ffp63279%3Enu%3D43%3C%3B%3E%3B45%3E257%3EWSNRCG%3D3343599765348nu0mrj)
![](http://images5a.snapfish.com/232323232%7Ffp63399%3Enu%3D43%3C%3B%3E%3B45%3E257%3EWSNRCG%3D3343599767348nu0mrj)
![](http://images5a.snapfish.com/232323232%7Ffp63259%3Enu%3D43%3C%3B%3E%3B45%3E257%3EWSNRCG%3D3343599776348nu0mrj)
![](http://images5a.snapfish.com/232323232%7Ffp633%3A5%3Enu%3D43%3C%3B%3E%3B45%3E257%3EWSNRCG%3D33435%3A%3B395348nu0mrj)
Ahh, the new one piece floor pan in the background![Winky](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_wink.gif)
Now I can cut the floor out and get the outriggers in for the cage.
![](http://images5a.snapfish.com/232323232%7Ffp63267%3Enu%3D43%3C%3B%3E%3B45%3E257%3EWSNRCG%3D334359%3C%3B86348nu0mrj)
![](http://images5a.snapfish.com/232323232%7Ffp63276%3Enu%3D43%3C%3B%3E%3B45%3E257%3EWSNRCG%3D33435%3A87%3C5348nu0mrj)
![](http://images5a.snapfish.com/232323232%7Ffp6324%3A%3Enu%3D43%3C%3B%3E%3B45%3E257%3EWSNRCG%3D33435%3A6858348nu0mrj)
![](http://images5a.snapfish.com/232323232%7Ffp63272%3Enu%3D43%3C%3B%3E%3B45%3E257%3EWSNRCG%3D33435%3A%3B334348nu0mrj)
Now it's off to the DC Performance in MD for the cage work. He did an outstanding job in half the time I could do it in (and half the wasted pipe lol)
One piece A-pillar bars through the dash and back to the main hoop.
![](http://images5a.snapfish.com/232323232%7Ffp6338%3A%3Enu%3D43%3C%3B%3E%3B45%3E257%3EWSNRCG%3D334%3A643967348nu0mrj)
![](http://images5a.snapfish.com/232323232%7Ffp63386%3Enu%3D43%3C%3B%3E%3B45%3E257%3EWSNRCG%3D334%3A64396%3A348nu0mrj)
![](http://images5a.snapfish.com/232323232%7Ffp63393%3Enu%3D43%3C%3B%3E%3B45%3E257%3EWSNRCG%3D3354529856348nu0mrj)
![](http://images5a.snapfish.com/232323232%7Ffp63388%3Enu%3D43%3C%3B%3E%3B45%3E257%3EWSNRCG%3D3354529857348nu0mrj)
Cage dropped down to weld the top
![](http://images5a.snapfish.com/232323232%7Ffp633%3A%3B%3Enu%3D43%3C%3B%3E%3B45%3E257%3EWSNRCG%3D335452%3A%3A82348nu0mrj)
![](http://images5a.snapfish.com/232323232%7Ffp63248%3Enu%3D43%3C%3B%3E%3B45%3E257%3EWSNRCG%3D335452985%3B348nu0mrj)
Brace hidden under the rear package tray
![](http://images5a.snapfish.com/232323232%7Ffp633%3A2%3Enu%3D43%3C%3B%3E%3B45%3E257%3EWSNRCG%3D335452%3A%3A89348nu0mrj)
Playing in the new jungle gym.
Got her back home. Next project is to install the floor and get her up on the rottisserie. Here is my 1 piece floor pan that I had to cut in 2 to make it fit.
![](http://images3a.snapfish.com/232323232%7Ffp733%3B3%3Enu%3D43%3C%3B%3E%3B45%3E257%3EWSNRCG%3D33588%3A%3B%3B9%3B348nu0mrj)
![](http://images3a.snapfish.com/232323232%7Ffp733%3B9%3Enu%3D43%3C%3B%3E%3B45%3E257%3EWSNRCG%3D33588%3A%3B%3B%3A2348nu0mrj)
![](http://images3a.snapfish.com/232323232%7Ffp733%3B3%3Enu%3D43%3C%3B%3E%3B45%3E257%3EWSNRCG%3D33588%3A%3B%3B%3A4348nu0mrj)
![](http://images5a.snapfish.com/232323232%7Ffp6338%3B%3Enu%3D43%3C%3B%3E%3B45%3E257%3EWSNRCG%3D33588%3A%3B%3B%3A5348nu0mrj)
Got that all done and the car off the lift and on the rottisserie. I picked up one of the new Aeromotive fuel cells with an in-tank eliminator series pump, so I gotta weld some brackets to it and make some mounts in the car. Welded in some 1 1/4" CM tubing just in front of the cell and I'm using the rear crossmember for the rear mount.
![](http://images3a.snapfish.com/232323232%7Ffp733%3A3%3Enu%3D43%3C%3B%3E%3B45%3E257%3EWSNRCG%3D337436%3C74%3A348nu0mrj)
welded some aluminum angle to the cell
![](http://images3a.snapfish.com/232323232%7Ffp7339%3A%3Enu%3D43%3C%3B%3E%3B45%3E257%3EWSNRCG%3D33743768%3A3348nu0mrj)
mounting studs tig'd into the tubing
![](http://images3a.snapfish.com/232323232%7Ffp733%3B7%3Enu%3D43%3C%3B%3E%3B45%3E257%3EWSNRCG%3D33743768%3A5348nu0mrj)
![](http://images3a.snapfish.com/232323232%7Ffp733%3A7%3Enu%3D43%3C%3B%3E%3B45%3E257%3EWSNRCG%3D33743768%3A9348nu0mrj)
Here's were I smoothed the firewall. I want to set the motor back in the car 2" so I made a notch for the pass. side to set in. The drivers side is where I got rid of the factory wiper mounting crap.
![](http://images3a.snapfish.com/232323232%7Ffp733%3A2%3Enu%3D43%3C%3B%3E%3B45%3E257%3EWSNRCG%3D3378677%3A55348nu0mrj)
![](http://images3a.snapfish.com/232323232%7Ffp733%3A%3A%3Enu%3D43%3C%3B%3E%3B45%3E257%3EWSNRCG%3D3378677%3A54348nu0mrj)
Had to replace a rusty panel
![](http://images3a.snapfish.com/232323232%7Ffp733%3B4%3Enu%3D43%3C%3B%3E%3B45%3E257%3EWSNRCG%3D3378677%3A53348nu0mrj)
![](http://images3a.snapfish.com/232323232%7Ffp733%3B%3A%3Enu%3D43%3C%3B%3E%3B45%3E257%3EWSNRCG%3D3378677%3A48348nu0mrj)
Here you can see the factory wheel tubs. They are next on the agenda
![](http://images3a.snapfish.com/232323232%7Ffp7339%3A%3Enu%3D43%3C%3B%3E%3B45%3E257%3EWSNRCG%3D3378677%3A44348nu0mrj)
![](http://images3a.snapfish.com/232323232%7Ffp733%3A7%3Enu%3D43%3C%3B%3E%3B45%3E257%3EWSNRCG%3D3378677%3A43348nu0mrj)
little bit of mini tub action (not so mini though)
![](http://images3a.snapfish.com/232323232%7Ffp733%3B5%3Enu%3D43%3C%3B%3E%3B45%3E257%3EWSNRCG%3D3378677%3A37348nu0mrj)
![](http://images3a.snapfish.com/232323232%7Ffp733%3A2%3Enu%3D43%3C%3B%3E%3B45%3E257%3EWSNRCG%3D3378677%3A34348nu0mrj)
![](http://images3a.snapfish.com/232323232%7Ffp733%3A3%3Enu%3D43%3C%3B%3E%3B45%3E257%3EWSNRCG%3D33786779%3C6348nu0mrj)
Ahh, got room for the new meats now! 345/34/18 MT Drag radials
![](http://images3a.snapfish.com/232323232%7Ffp733%3C4%3Enu%3D43%3C%3B%3E%3B45%3E257%3EWSNRCG%3D337436%3C759348nu0mrj)
Laying out the trunk tin work
![](http://images3a.snapfish.com/232323232%7Ffp733%3B2%3Enu%3D43%3C%3B%3E%3B45%3E257%3EWSNRCG%3D33743768%3B9348nu0mrj)
![](http://images3a.snapfish.com/232323232%7Ffp733%3A9%3Enu%3D43%3C%3B%3E%3B45%3E257%3EWSNRCG%3D33743878%3C3348nu0mrj)
I cut out the toe kicks in order to make some recess's for my turbo downpipes
![](http://images3a.snapfish.com/232323232%7Ffp73398%3Enu%3D43%3C%3B%3E%3B45%3E257%3EWSNRCG%3D337438794%3B348nu0mrj)
![](http://images3a.snapfish.com/232323232%7Ffp733%3B%3A%3Enu%3D43%3C%3B%3E%3B45%3E257%3EWSNRCG%3D337436%3C766348nu0mrj)
My Little helpers love to pitch in on the project with thier Dad!
![](http://images3a.snapfish.com/232323232%7Ffp733%3A8%3Enu%3D43%3C%3B%3E%3B45%3E257%3EWSNRCG%3D337436%3C777348nu0mrj)
Right after I told them there was a stink bug in the tire.![The Jester](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_jest.gif)
![](http://images3a.snapfish.com/232323232%7Ffp733%3A%3A%3Enu%3D43%3C%3B%3E%3B45%3E257%3EWSNRCG%3D3374387965348nu0mrj)
Bangin gears early!
![](http://images3a.snapfish.com/232323232%7Ffp733%3B2%3Enu%3D43%3C%3B%3E%3B45%3E257%3EWSNRCG%3D33786779%3C3348nu0mrj)
Bangin gears early!
awsome. your goal for a street car that can go 8s is not a dream
if my 3600 lb s10 all steel with full interior can go 8.80s drive all over on pump e85 and a stock 010 block with no hard block. for 3 yrs. i think its deff doable.
maybe u should make your goal 7s.!!!!!!
Thanks! I'm putting the power from the silver car in it, but I only got to run it once last year. It went 9.32 @ 152 at 14psi. I'm figuring that 8s should be pretty achievable. I would really like to see 8.50s. This car should be alot lighter and alot stronger so I'm hoping she'll do it.
Wow awesome project! ive got a friend with a completed 55 chev with a BB and twin 88's another friend is working on a turbo falcon.
i really enjoy seeing the progress and cant wait to see it finished!
![Thumb](https://ls1tech.com/forums/images/smilies2/thumb.gif)
More rust repair![Bang Head](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_banghead.gif)
![](http://images3a.snapfish.com/232323232%7Ffp73396%3Enu%3D43%3C%3B%3E%3B45%3E257%3EWSNRCG%3D3374387967348nu0mrj)
![](http://images3a.snapfish.com/232323232%7Ffp733%3B3%3Enu%3D43%3C%3B%3E%3B45%3E257%3EWSNRCG%3D337864%3B6%3B8348nu0mrj)
![](http://images3a.snapfish.com/232323232%7Ffp733%3C2%3Enu%3D43%3C%3B%3E%3B45%3E257%3EWSNRCG%3D3374387969348nu0mrj)
Here I made some braces from the factory frame rails/bumper mounts to the new frame rails.
![](http://images3a.snapfish.com/232323232%7Ffp733%3C3%3Enu%3D43%3C%3B%3E%3B45%3E257%3EWSNRCG%3D337864%3B6%3B2348nu0mrj)
![](http://images3a.snapfish.com/232323232%7Ffp73397%3Enu%3D43%3C%3B%3E%3B45%3E257%3EWSNRCG%3D3378639572348nu0mrj)
![](http://images3a.snapfish.com/232323232%7Ffp733%3A8%3Enu%3D43%3C%3B%3E%3B45%3E257%3EWSNRCG%3D33786642%3B9348nu0mrj)
Made some gussets for the front of the spring pockets
Making the pedal mount with dual reverse master cyl. and bias bar.
![](http://images3a.snapfish.com/232323232%7Ffp733%3C3%3Enu%3D43%3C%3B%3E%3B45%3E257%3EWSNRCG%3D33786642%3B7348nu0mrj)
![](http://images3a.snapfish.com/232323232%7Ffp733%3A3%3Enu%3D43%3C%3B%3E%3B45%3E257%3EWSNRCG%3D33786642%3B6348nu0mrj)
mounting tabs for the adjustable transmission crossmember.
![](http://images3a.snapfish.com/232323232%7Ffp733%3C2%3Enu%3D43%3C%3B%3E%3B45%3E257%3EWSNRCG%3D3378639568348nu0mrj)
![](http://images3a.snapfish.com/232323232%7Ffp733%3B3%3Enu%3D43%3C%3B%3E%3B45%3E257%3EWSNRCG%3D33786753%3C5348nu0mrj)
Started making the crossmember for the rear shocks
![](http://images3a.snapfish.com/232323232%7Ffp733%3A4%3Enu%3D43%3C%3B%3E%3B45%3E257%3EWSNRCG%3D3378639569348nu0mrj)
![](http://images3a.snapfish.com/232323232%7Ffp733%3B%3A%3Enu%3D43%3C%3B%3E%3B45%3E257%3EWSNRCG%3D33786642%)
![](http://images3a.snapfish.com/232323232%7Ffp733%3B5%3Enu%3D43%3C%3B%3E%3B45%3E257%3EWSNRCG%3D3378675%3A%3C7348nu0mrj)
![](http://images3a.snapfish.com/232323232%7Ffp7339%3A%3Enu%3D43%3C%3B%3E%3B45%3E257%3EWSNRCG%3D3378675%3A%3C6348nu0mrj)
Also welded on some tie downs to make life easier if she goes in a trailer
