new to boost have questions?
Old Mar 9, 2011 | 04:40 PM
jbrenner0188's Avatar
Default new to boost have questions?
i have a 01 ss stock motor with a p1sc and 48lbs. injectors and full exuast.i am puting a big fuel pump in next,then i want to do heads and cam right away what to get???i heard good about the epp cam...car has 2800 stall and a 4l65 convertion?what does this consist of ? looking for 6's for rwhp if possable.any other good ideas for my build to save from the bad later?
Old Mar 14, 2011 | 07:18 AM
Bob@BruteSpeed's Avatar
LS1Tech Sponsor
Active Streak: 30 Days
Active Streak: 60 Days
Since you have a stock bottom end, I would add a cam, http://shop.brutespeed.com/Comp-Brut...-Camshaft.htmb pushrods and valvesprings, and keep the boost at 8 psi. Over the years I have seen that when you add a cam and better flowing heads at 8 psi, it ends up being too much for the stock pistons. With heads and a cam you'd have a hard time making 8 psi with the P-1SC anyway.
You're more than likely need to upgrade to 60lb injectors as your injectors will probably me maxed out. Bob
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
Old Mar 19, 2011 | 02:55 AM
TheZDeWolfe's Avatar
wow.. wait a minute here not trying to hijack your tread but. maybe i read wrong. when you said with heads and cam youll have a hard time making 8 lbs.? explain this are you saying your fuel will run out. or the p1sc cant make that power? pm me on this.
Old Mar 19, 2011 | 07:43 AM
LS1Tech Sponsor
The P-1SC will have to be spun very hard to make 8 psi with heads and a cam. It's straight blade impeller just isn't very efficient at grabbing the air. The 6 rib crank pulley is only 6.00" dia and you'll end up with a tiny blower pulley which will result in very little belt wrap that causes belt slippage. Bob
__________________
Old Mar 19, 2011 | 08:36 PM
nodrok's Avatar
And Bob has spoken
Old Mar 19, 2011 | 08:50 PM
LS1Tech Sponsor
Talking
Originally Posted by nodrok
And Bob has spoken
3 cups of coffee and I have my moments. Bob
__________________
Old Mar 20, 2011 | 01:13 AM
LOL! okay so let me get this straight. im looking at the p1sc kit for mine.. so its a lot smarter to get a 8 rib pulley setup. but would it be smarter to just wait for the D1, instead i want 8 to 12 lbs being on heads and cam. I mean be honest worth the wait or is it achievable with p1 and not slipping belt and working the hell out of it!?? lol
Old Mar 20, 2011 | 01:16 AM
or how about just a cam. with stock ls1 heads? still make 8 lbs okay? what i wanna do is meth mine with 10 lbs. but i was considering the 317 heads and well its a for sure im going the blower cam. im just trying to do my homework before i take this on. eventually i will do a 6.0 block forged and what not. but sorry again about Hijacking. your tread just got me going lol
