60lbs injectors for turbo build or go larger?
So I have my tc78 single turbo goin on a forged ls1 (stock cubes) and plan on pushing mid high teens in psi and aiming for 700-750whp. I have the lonnies dual pumper setup and some 60lb injectors. Talking to Lonnie he thinks I will be fine with the 60's, but most others I talk to say go 80's. I trust Lonnie to know these setups pretty well, but his concern is me havin idling issues with the 80s and he's seen 60's on 800+whp builds. Also he mentioned that the bigger bottleneck isn't the 60's at that power level, but the fuel lines and rails. What do you guys think? I've been debating it back and forth.
With my last setup, I was seeing 100 - 110 duty cycle at 14 psi with h/c/i 408 with pt88. I think once you turn up your turbo you will be past the safety you should have. I upgraded to 80s, just for the reason I didn't feel like messing with low impedance injectors.
