Good intercooler for 900whp?
Old Mar 14, 2011 | 10:11 AM
Vetal's Avatar
Originally Posted by ChevyChad
Dude, I thought the whole reason you made this thread was because you got a crap IC from ebay.. Just wondering why you think your solution is another ebay IC?
well technically not from Ebay but company called SSAutochrome:
http://www.ssautochrome.com/prod.itml/icOid/1777
And because I see many people have success with CXRacing intercooler, I want to give it a try
P.S. I measured the core and it wasn't even 4", more like 3.5
Old Mar 15, 2011 | 06:22 AM
Vetal's Avatar
Are Treadstone intercoolers significantly better? Any sponsor on here sells them?
Old Mar 15, 2011 | 11:42 AM
mattster03's Avatar
I think treadstone intercoolers are superior; if not in flow rates, in build quality for sure. I would go with their TRV25 or TRV259 vertical flow IC. If you are able to flow straight into your Intake over the radiator with a TRST this is where the LS1 motors make their best power.
Old Mar 15, 2011 | 11:51 AM
Vetal's Avatar
I can't see how would I fit IC with outlet over radiator
Old Mar 15, 2011 | 01:21 PM
mattster03's Avatar
I'm just stating options... plus there's a Nissan in your signature, I thought maybe it's LS1 swapped and what this thread is about. In the LS1 RX7 world there are a few guys running 45 degree radiators with intakes over the front.
Old Mar 15, 2011 | 01:35 PM
Vetal's Avatar
you see Nissan displacement in there?
but yeah, I would love to have vertical flow cooler but can't see it fit...
Old Mar 15, 2011 | 02:13 PM
ChevyChad's Avatar
8 sec potential, 12 sec slip
The APS TT system uses such an intercooler for the fbodies.. But it has dual inlets though, plus its probably more than you would want to pay I'm sure..
Old Mar 15, 2011 | 02:18 PM
Vetal's Avatar
How is outlet routed then?? I'm sure it's more but there must be affordable coolers with single inlet
Old Mar 15, 2011 | 02:21 PM
ChevyChad's Avatar
goes right up over the radiator... Should be some pics in here that you could find by searching I'm sure.
Old Mar 15, 2011 | 02:23 PM
ChevyChad's Avatar
quick google search:
Old Mar 15, 2011 | 02:35 PM
blown99bergerssclone's Avatar
Mine says godspeed on it.. Is that the same as the CXracing? I got mine on ebay a few years ago. Its core size is 24x12x4.
http://i24.photobucket.com/albums/c1...utOfTheBox.jpg
http://i24.photobucket.com/albums/c1...l/HorizMU1.jpg
Any other install pics? Would I wrk mounted the same on a camaro?
Old Mar 15, 2011 | 02:41 PM
  #32
Vetal's Avatar
ChevyChad, I wanted to see how it's installed, cause I can't imagine it with stock hood without lowering radiator all the way to the ground...
Old Mar 15, 2011 | 03:39 PM
  #33
ChevyChad's Avatar
Lots here: https://ls1tech.com/forums/forced-in...c-project.html
Straight off APS's website:
http://www.airpowersystems.com/fbody/tts2.htm
Old Mar 15, 2011 | 04:07 PM
  #34
John H's Avatar
Air-to-water!
Old Mar 15, 2011 | 04:08 PM
  #35
Vetal's Avatar
Thanks! I see where's the problem with my setup - my turbo is mounted in front of the engine so rad is moved forward and there's no space for IC outlet to go over it without cutting upper rad support and putting higher WS6 hood
Old Mar 15, 2011 | 04:15 PM
  #36
bad6as's Avatar
i run a ebay 4" core on mine. 15lbs i made 650 ish wheel on a lazy timing curve. thats threw a th400, 3800 stall, 28" drag radials.
i only stoped because i ran out of injector.
at 900 wheel im sure it is a restriction compared to a open pipe. but comapred to a high dollar unit? im sure it dosent flow as well. but from a cost stand point. you get what you pay for.
but you will never see 900 whp with that tc78
Old Mar 15, 2011 | 04:28 PM
  #37
Vetal's Avatar
Well I didn't sign contract to keep TC78 forever At the very least, Precision 76HPS would fit in there for not much more $$$. And if I'm lucky and heads stay bolted even at 1200HP, I'd just move rad further away, or replace stock fans with thinner, and put T6 in there.
In short, I WOULD LIKE, IF POSSIBLE, to see some 10-20% reserve with current 1000HP rated turbo
Old May 13, 2012 | 11:22 AM
  #38
Punisher_ws7's Avatar
I have a cxracing ic. And am seeing a 9-10pic psi drop from charge side of intercooler to engine
Old May 14, 2012 | 03:01 AM
  #39
Vetal's Avatar
I would say you have to narrow down the problem spot If it was me I would first measure drop right at the IC discharge pipe
Old May 14, 2012 | 03:54 AM
  #40
stevieturbo's Avatar
I find that impossible to believe.
@ Vetal.
Are you looking for an identical replacement, or a custom unit to be made, or simply a better core for your existing end tanks ?
Can you do any fabrication yourself ?
There are plenty of companies in the UK that can make complete units, or just supply you a core to weld onto your existing end tanks
As others have said, if you genuinely believe the core is the problem, then it is throwing money away just buying another cheap Chinese core which will be identical.
Another option might be if you can find an aftermarket IC as used on Nissan Skylines, as generally they are pretty big with well designed end tanks. The biggest failing on all the cheap chinese cores is the terrible end tank design which does nothing to promote even or good flow through the actual core.
Even if you were to cut them off and add maybe an inch or so of a spacer to give the end tank more volume it would help flow.
