Exhaust temp coating
Old Mar 14, 2011 | 10:56 PM
XtremeDime's Avatar
Default Exhaust temp coating
I want to get my hot side coated but we dont have anyone up here that does "ceramic" coating in Alaska but 1 shop does offer high temp coating. He says it is good to about 1700 degrees. How hot does the hot piping get??
Old Mar 14, 2011 | 10:58 PM
madmax4499's Avatar
not sure how hot it will get. send your parts to performance coatings in auburn, wa. 2000 degrees looks great. inside and out.
Old Mar 14, 2011 | 11:07 PM
XtremeDime's Avatar
Im not going to spend over 1k for coatings haha. It would cost almost 400 for shipping back and forth. Alaska sucks sometimes...
Old Mar 15, 2011 | 12:40 AM
408trans_am's Avatar
Closed ex-Sponsor Account
Well there are a few new ceramics you can shoot yourself out now. They still require a decent setup with a exhaust fan booth to pull vacuum of some sort and spray through an air brush gun. Some are air dry to touch and full cure on first heat cyle of the engine. Still probably gonna cost a decent amount.
Why don't you just use header wrap? Cheap and actually works better than ceramic coating. Not as pretty or clean as coating though.
Old Mar 15, 2011 | 01:25 AM
XtremeDime's Avatar
I was going to do it mainly for aesthetics lol
I think I might just wrap it >.<
Old Mar 15, 2011 | 01:54 AM
Camaro Chris's Avatar
There is a friend of mine here that does coating that are good for 3000 degrees constant. he tested a 90mm turbo mustang and on the dyno, It lowered engine bay temps by 87 degrees PM me if you want info he will let stuff be shipped. and he is EXTREMELY affordable
Old Mar 15, 2011 | 09:40 AM
1320's Avatar
3000 degrees? Piston coat is rated to 2000..........most ceramic header coatings are 1300-1600......
Old Mar 15, 2011 | 10:09 AM
My2kz28's Avatar
Have you looked at the jet hot 2000?
Old Mar 15, 2011 | 10:23 AM
PRAY HRD's Avatar
Where is he out of? That 3000* **** is supposed to be pretty damn good at not changing colors too! I think you can just post his info on here since there aren't any sponsors who do coating. PM me if you'd prefer though.
Thanks!
Old Mar 15, 2011 | 01:47 PM
Boosted One's Avatar
I did my ceramic coating myself. It's not too bad to do if you have a oven large enough for the parts. I used TurboX flat black coating. THere should be some pics of the coating process in my build thread in my sig.
Frank
Old Mar 15, 2011 | 03:44 PM
-Q-'s Avatar
-Q-
When I had my '75 Corvette up there, I had the headers and side pipes ceramic coated by Advanced Powder Coating out in Big Lake...do they not do it anymore?
Old Mar 19, 2011 | 04:37 AM
Well if it O.K to post his info, this is the best way to view his stuff because he is still having his website put together. http://www.facebook.com/#!/UnknownCoatings he just finished my wheels and brake calipers and all I can say is WOW these things look great!!! Yeah, I'm missing a lug nut. can not find it anywhere, somewhere between his shop and my shop I lost it FML but he did the black wheels and pink stuff.
Old Mar 19, 2011 | 05:29 AM
Oh I forgot to add, he has a coating for Aluminum that ups the heat dissipation efficiency by 47% he can do intercoolers and cold side piping.
Old Mar 19, 2011 | 08:45 AM
XtremeDime's Avatar
I asked him about ceramic coating and he said he only had a high temp coating. Im pretty much only doing it for aesthetics anyway. He said he would do my entire kit for 350. Gonna bring it out to him on Monday after I clean up these shitty welds...
