Procharger set up advice.
I figure the better flow won't hurt. I just really don't want to get into a head swap yet. Really don't want to cam it yet either but will if I have to. BTW 10# didn't hurt the stock engine?
Really?? Yeah you don't need to change heads and cam to make power with FI but changing the heads and cam allows you to make more power with out working the blower harder. When you run a more restictive head you are making more boost and creating more heat in the Charger air than it you would have used a better flowing head.
Then do a set of 317 heads and the Brute speed cam.
Then add the Meth. After that I would look into building a forged short block.
Like said I have a buddy that just removed his stock short block from his car in perfect running order after over 1 year at over 600 rwhp from the above combo. Only reason he removed the motor was for a forged 383 short block.
Lets face it the boost and power is addictive and we keep wanting more and more.
You can spend as much money as you want with increasing engine flow (heads, cam) but in the end you will make the same power, just spend more money doing it. And remember swapping the cam will decrease valvetrain longevity, its all a trade off. Lots of people making 550rwhp on the stock longblock though without spending $1000+ on heads/cam.
D1 4.5" pulley + LS1 heads + LS1 cam = 8psi = 520rwhp
D1 4.5" pulley + better heads + blower cam = 6psi = 540rwhp
D1 4" pulley + LS1 heads + LS1 cam = 11 psi = 560rwhp
D1 4" pulley + better heads + blower cam = 9psi = 580rwhp
Remember the blower only moves so many CFM at a certain speed, that mostly dictates your power output. Getting a smaller pulley to begin with costs $0. Getting heads/cam costs $1-3k, and you can sacrifice valvetrain longevity and torque with the wrong combo. So IMO if you are getting into boost for the first time when there will inevitably be many little costly gremlins that will pop up, I would not feel the need to spend a lot more money up front to make the flow slightly more efficient.
You forget that heads and cam not only help intake efficiency, they help exhaust as well. Yes, it is true that getting air into the cylinders is nowhere near as critical on an FI application compared to N/A since yes- your head unit will be outputing a set cfm based on pulley size.. However, thats only half the equation buddy.. You need to get that air OUT of the system too. Better heads and cam will shine in this area on an FI application. You can not neglect that effect.
That all being said, I still say that for the OP's goal of 500ish HP, stay with the stock shortblock, upgrade to LS6 intake, get some good headers, and the next thing on the list I'd recommend would be a meth kit.
And to answer your question jastone about the tune- your car will likely start and run good enough to drive it to get retuned, but definitely get a re-tune after heads and cam. Especially on FI. By no means should you beat on it with those mods without a re-tune.
Thanks for all your info man, and to everybody for that matter. I've learned more tonight than I have in the 2yrs I've been lurking in this section. All you guys have been very helpful to me
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
Glad you finally agreed that heads/cam aren't needed for the OP's goal though, I am just trying to save some unnecessary money since I have been through the same situation.
No need to pollute this thread with anymore bickering or BS. There is actually a good bit of info in here, so no need to add clutter.
