Compression Ratio - What cc heads
Old Mar 17, 2011 | 03:02 AM
rmata's Avatar
Default Compression Ratio - What cc heads
I'm thinking about putting a motor together for my corvette. A 402 with -15cc pistons. Never done a boosted setup before so what would be a good compression ratio to shoot for so that I can know more or less what CC heads I need to go with. I'm only looking for 7-800hp on kill mode and relative lower for just cruising around. Also it will probably be ran n/a for about a year to break in the motor and beef up the rest of the drivetrain before a kit goes on, so I don't want it to be too weak of a motor before it gets boosted. Let me know your opinions and what you can get away with without hurting the motor later down the road. Thanks
Old Mar 17, 2011 | 03:40 AM
XtremeDime's Avatar
You could run 11:1 compression without hurting a motor, as long as you can provide a high enough octane to prevent detonation. Are you looking to run pump gas at all?
Old Mar 17, 2011 | 04:49 AM
rmata's Avatar
Oh, I guess I forgot to mention that this would be on pump gas.
