LT1 with Ysi
Old Mar 19, 2011 | 11:46 AM
kazdevil's Avatar
Default LT1 with Ysi
Who makes cog setup for LT1 with Ysi ? Anyone one has a cog setup for sale?My 8 rib is not holding anymore. Can't get pass the 725rwhp without belt slip.
Old Mar 19, 2011 | 01:40 PM
Grr's Avatar
Grr
what size pulleys you looking for? If you want to do it cheap you can do the 10-rib like I had on mine, would end up with 7.8"/3.12" or 2.95". LMK ill get you more info if you want
Gary
Old Mar 19, 2011 | 01:46 PM
Grr's Avatar
Grr
You still running the 7"/2.75" 8-rib you had before? If so thats 2.54 ratio
A 7.8"/3.12 is 2.50 so that would be pretty close with a large increase in pulley diameter
Old Mar 19, 2011 | 05:03 PM
kazdevil's Avatar
What hp are you making now with 10 rib? Any noticeable belt slip?
Old Mar 19, 2011 | 06:38 PM
T/A KID's Avatar
I remember you having issues with this car, glad to see its making the power it should be now. What was wrong with it??
Im a procharger guy so it may be different, but what about a Spring loaded tensioner? I have seen guys run a 8-rib on an F1A with it.
Old Mar 19, 2011 | 07:15 PM
kazdevil's Avatar
At first the car made 671rwhp :
8rib 2.75''/7'' pulley., spring tensioner
vortech aftercooler
max power was @ 11 psi
then I changed the aftercooler to a slightly bigger one gained 1-2 psi more and the car made 718rwhp.
after that I changed the camshaft to a solid roller, boost didnt change..made 725rwhp.
found pressure drop across the IC. I removed the aftercooler and with a direct duct to the intake and installed water/meth injection.
Gained 3-4 psi of boost, but NO hp gain.- It might to do with spark plugs gap too big 0.060 though I didnt notice any misfire and the dyno graph was smooth.- "your thoughts and inputs here please".
Fitted 8'' crank pulley- aiming for maximum boost- and this when my belt start to slip and I only seen 8-10 psi and the car made ~630 rwhp.
So, this why I am after a cog setup.
Old Mar 20, 2011 | 01:08 PM
Grr's Avatar
Grr
the car hasnt changed since I sold it, was making around 630whp with a forged 355 and stock LT1 heads. 7.8"/3.12" and about 14psi. Once I got the belt tied down tight I had no issues up to 6800rpm. The inlet was very restrictive, I took it off one day and it was making over 18psi at 5500rpm, but I just sold the car instead so I never screwed with it. I posted info and pics in one of your other threads
Doing a cog setup is going to cost at least $1000 but then you will never have to worry again, I had about $450 in my whole 10-rib setup
Old Mar 20, 2011 | 03:52 PM
kazdevil's Avatar
Who makes cog setups? Do you have his contact info?
Thanks
Old Mar 20, 2011 | 04:09 PM
Grr's Avatar
Grr
Call ASP racing, they are who made my old cog kit. They can make you basically anything you want. Dont go lower than 28t on the blower, I had a 26t and couldnt keep teeth on the belt
http://www.aspracing.com/index.html
Old Mar 20, 2011 | 07:37 PM
1toofastlt1's Avatar
I will be running a 7.8/3.33 8 rib with a V1 and no intercooler. what kind of boost will that make?
