Vacuum Leak/Limited Boost
Old Mar 22, 2011 | 03:10 PM
whiteboycntdnce's Avatar
Default Vacuum Leak/Limited Boost
Ever since the car has been FI the vacuum gauge has read consistent 15" cruising, and 20" when it's pulling on the motor. Last weekend, I noticed the blower making a strange "Chirp" sound which I have never heard it make before, then when I looked at the boost gauge it was only pulling ~7" cruising, and only 10" against the motor. Also, the blower is only making 5 pounds of boost.
I was wondering if anyone has any ideas on where to start looking for the vacuum leak, of if any of you have gone through this before. Thanks!
Old Mar 22, 2011 | 06:18 PM
barnat's Avatar
Is the crank pinned or keyed?
Are you getting any belt slippage?
Sounds like somethings slipping from the noise.
Ide check both of these first and go from there
Old Mar 22, 2011 | 10:20 PM
Belt slip isn't an issue... Will be towing the car to a friend's house, there we'll take off the blower hat, looking for any damage. Then a leak down test will be done... Keeping my fingers crossed.
Old Mar 22, 2011 | 10:57 PM
blue00ZZleeper's Avatar
It sounds more like a vacuum leak. I had this similar thing happen to my car minus the weird sound. It turned out it was the gasket between the throttle body and intake manifold. It made a little noise but not a chirp...I'd check the easy **** and then do a leak down but the sound you described is weird lol. Good luck man!
Old Mar 23, 2011 | 06:12 PM
The car's going back to AFASTYZR1's tonight for an inspection of the blower, couplers, and a leak down test... Crossing my fingers!
Old Mar 23, 2011 | 09:37 PM
9t8z28's Avatar
What intake and what blow off valve?
Old Mar 24, 2011 | 07:44 AM
I'm running the LS6 intake, and the Turbonetics Godzilla Bypass
http://www.summitracing.com/search/B.../?autoview=SKU
Old Apr 2, 2011 | 08:59 PM
firepwr's Avatar
Any updates?
