best 2 step?
Old Mar 24, 2011 | 05:50 PM
Busy Mopper's Avatar
Default best 2 step?
just got my th400 with trans brake. lookin for the best 2 step to build boost with from the line? how many lbs of boost are yall seeing with the footbrake?
thanks
Old Mar 24, 2011 | 06:21 PM
ablakez28's Avatar
In for results. I have the MSD plug and play unit from my old NA setup but have been told I need something with timing retard as well now to help build boost.
4SFEDSS's Avatar
I would go with an MSD. I had a lingenfelter first but right out of the box it was defective, the car ran terrible. So i pulled it off and got an msd and it worked great. The msd is also alot smaller in size, and i beleive its cheaper too.
Old Mar 24, 2011 | 07:41 PM
boosted LT1's Avatar
I use the MSD 6AL so the MSD two step was a no brainer and works like a charm.
Good luck
Old Mar 24, 2011 | 07:42 PM
how much boost are you building with the msd? also ive heard of the ligenfelter ones just straight up not working at all our of the box? so idk if i would buy that
where do these plug into?
Old Mar 24, 2011 | 07:51 PM
I am footbrake and set my RPM low (3000) because I need to limit my boost at launch to be able to drive the car. I build I think 3 psi and it enabled 1.32 60 and it carries front end 1st, 2nd and it comes down in drive ~60 foot
Friend with a Tbrake can build whatever boost he wants. Each setup is different.
Good luck
Old Mar 24, 2011 | 07:58 PM
Search on site or online. There is a location for a RPM 'pill' on an MSD 6 AL this is the 'rev' limit point. The two step plugs into the pill location and enables selecting channel one (line RPM) or channel two normal rev limit.
Good luck
Old Mar 24, 2011 | 10:31 PM
4SFEDSS's Avatar
For an LS engine theres no need for a msd 6a box or anything like that. The MSD LS specific 2 step plugs into both banks of coils and then just your activation wire, either power or ground. Doesnt get much easier. Theyre all factory style connectors.
 Michael S. Palmer
Old Mar 25, 2011 | 07:56 AM
That is perfect. Can someone link me on the box with the pills. Searched but all we found was the 70 dollar 6al and then the 270 dollar one, im assuming this is it?
Thanks again mate
Old Mar 25, 2011 | 03:09 PM
4SFEDSS's Avatar
The msd part number is 8733. There are no pills, it has rotary dials for adjustment.
Old Mar 25, 2011 | 03:34 PM
ablakez28's Avatar
The MSD one that plugs in is what I have from my NA setup. Is this the best setup for a 6-sp car or should I be looking at something else?
Old Mar 25, 2011 | 06:08 PM
tomz28's Avatar
LPE 2-step here. it has been good to me so far have not used it with the Auto yet. but that is going down soon. and i here the 3-step is great for auto turbo cars. you can set a rpm for the footbrake when you building boost before the beams, let the car creep into the staging lights than hit the transbrake that has its own rpm set point on the 3-step. i hope that makes sence.
you can do it this way to stay on the transbrake for the smallest amount of time to cut down on trans temps
have not done this my self but it sounds like something id like to try out
i need a WAY better 60 foot with my car LOL
Old Mar 25, 2011 | 07:50 PM
what is the differences between two step and three step?
Old Mar 25, 2011 | 10:16 PM
tomz28's Avatar
you have one more rpm set piont with a 3-step for what ever you need
