GM 12626958-LSA heads
Old Dec 29, 2010 | 12:17 PM
ajensen383's Avatar
Default GM 12626958-LSA heads
Just wondering if anyone has any experience with these heads... Alot people seem to want to run the L92, but are afraid of the thin decks, wouldnt these be the "answer" from GM for boosted economical heads at about $450 each that would be able to hold boost??? Any thoughts??
Old Dec 29, 2010 | 12:21 PM
98Z28CobraKiller's Avatar
Restricted User
My understanding is that its the same casting with a different valve configuration. I could be wrong.
Old Dec 29, 2010 | 12:38 PM
ajensen383's Avatar
Here is a write up I found about them.....They seem better than the standard L92/LS3
"The 6.2L Supercharged LSA cylinder heads are similar to those used on the naturally-aspirated 6.2L LS3 Corvette V-8, with enhancements for supercharged induction and maximum durability.
The LSA heads feature a unique “wing” cast into each intake port to promote a swirling motion that blends the pressurized air-fuel charge. The heads are also cast from a premium A356-T6 alloy, which better manages the heat generated in a supercharged engine. A356-T6 pays particular dividends in the thin bridge area between the intake and exhaust valves, where effective heat dissipation is crucial to both performance and long-term durability. Finally, the LSA heads are rotacast. This process rotates the head mold as the molten alloy cools and essentially eliminates porosity, or microscopic pockets of air trapped in the casting. Rotacasting delivers a stronger part that helps maintain performance and structural integrity over the life of the engine"
Old Dec 29, 2010 | 12:59 PM
Louis at GSS's Avatar
It is a better alloy, which helps. Dont forget, Im not sure if the LSA has it, but the LS9 has bigger/larger head bolts as well as the multi layer gasket.
Old Dec 29, 2010 | 01:49 PM
veee8's Avatar
LSA does have the MLS gaskets, but stock GenIV diameter head bolts. That funky air wing ends up being a restriction as boost and power increases.
Old Dec 29, 2010 | 05:41 PM
ajensen383's Avatar
At what power level would this occur??? Depending on what level the wing becomes a problem it seems like it would be a superior head compared to the L92 due to the extra head thickness and the rotacasting
Old Dec 29, 2010 | 06:08 PM
rotary1307cc's Avatar
I went from L92s to a set of LSA's to try
I got a new set ported from Richard at WCCH
It uses a better material and better casting technique than the standard L92
LSA's use the normal LSX head bolt diameter
I can tell you the castings look WAY nicer than my old L92s
Just look how nice the as cast chambers are...
No one really knows if the decks are actually thicker or not, they do have more heft in other areas though like the intake flange
If anyone wants to try a set i have a pair that have maybe 10 miles on them i picked up from See5 (bruce) on Tech that i would sell for cheap
I bought them and then just decided to buy a fully ported set from WCCH instead of waiting to send those in
Old Dec 29, 2010 | 07:07 PM
98_LS1's Avatar
What did WCCH have to say about the air wings in the lsa heads??
Old Dec 29, 2010 | 07:43 PM
They cut quiet a bit of the wing out, some still there
Old Dec 30, 2010 | 09:55 PM
1SlowHoe's Avatar
Destroyer of Transmissions
I spoke to Richard today and ordered a set of worked LSA heads for a project. He said they flow close to the same but the LSA was a better material and you can get a bigger combustion chamber out of an LSA (75cc) vs. a L92 (72cc). All depends on your needs.
Old Jan 23, 2011 | 09:57 AM
NemeSS's Avatar
Old Jan 23, 2011 | 10:34 AM
PRAY HRD's Avatar
Wow 75cc chambers?? Thats enticing for me switching from a 11.2:1 CR n2o 62cc setup trying to get to a more boost friendly sub 10:1 CR! I didn't realize anyone made anything bigger than 72cc. Any idea what kind of power these would support on a 402?
Old Jan 23, 2011 | 12:37 PM
Yep mine where finished at 75cc
Old Jan 23, 2011 | 01:48 PM
1SlowHoe's Avatar
I don't know ....yet I'm putting mine on a 408 (10.4:1CR) in my Tahoe. Topping it off with a TVS2300. Hoping for 12-15psi. We will see what I can do with my less than boost perfect CR. Meth injection is already in the garage if needed.
Old Jan 23, 2011 | 08:50 PM
PRAY HRD's Avatar
Cant wait to hear how they do! Just be sure to tune without the meth and then just use it for more power beyond it. I've heard too many horror stories of tuning FOR the meth setup and a pump fails and kaboom! bye bye motor!! I wanna use meth too but not rely on it. Eventually when the motor needs to be freshened up i'll have it built boost friendly all the way. Good luck!!
Old Jan 24, 2011 | 06:22 AM
68 SS's Avatar
I bought the set that rotary1307cc had for sale they are now at WCCH getting the port work done and having the chambers cut. I am going to put them on my LSX block with a F1R...we will see if they are the hot ticket!
Old Jan 24, 2011 | 10:30 AM
PRAY HRD's Avatar
I'm guessing the big concern is weather or not these can take over 20 psi correct? They should be just fine for the 15 psi i will eventually be running i hope. Now i wonder how much of an issue that wing is??
Old Jan 28, 2011 | 03:06 PM
68 SS's Avatar
They cut most of the wing out when they CNC them, at lower boost levels I would not think it would hurt you too much but I have not seen stock LSA flow numbers.
Old Jan 28, 2011 | 05:29 PM
Kory 88Iroc Lt1's Avatar
I wonder if they would flow the same as stock l92 heads with just the wing removed?
Kory
Old Jan 28, 2011 | 05:43 PM
1SlowHoe's Avatar
Flow charts here:
http://www.proheads.com/datasheet.html
