has anyone made a bolt on vertical radiator mod?
Old Mar 27, 2011 | 03:17 AM
I_Need_Land's Avatar
Default has anyone made a bolt on vertical radiator mod?
i got to thinking, it would be super easy to pop off the hood, and drive the engine/trans straight in the core support area if you had a bolt on upper rad support. anyone done anything like this? im probably going to do it in the am, so worst case scenario i will provide some pics.
Old Mar 27, 2011 | 09:00 AM
408trans_am's Avatar
Closed ex-Sponsor Account
Yea I have done a few and also seen a few done as well. The reason most will just weld the upper in is for ease and strength. If you want a removable one make sure the caps you use to enclose the upper support are thick and completley welded. Then make the crossbar with at least 2 decent size bolts per side. To make it easier I usually weld the nuts to the outter supports so you just have to align the bar and bolt it in.
The lower support is easy as you can just bolt it right through the frame rails. Ill post pics later to help ya out.
Old Mar 27, 2011 | 09:13 AM
fast00ls1's Avatar
I would like to see pics as well.iam about to do something simular
