Procharger kit
Old Apr 1, 2011 | 10:56 AM
ChevyChad's Avatar
8 sec potential, 12 sec slip
the standard valve wont suffice very well for boost over 8-10psi. And that is about the minimum boost you will get from an F1 blower.
Old Apr 1, 2011 | 11:35 AM
Bob@BruteSpeed's Avatar
LS1Tech Sponsor
Active Streak: 30 Days
Active Streak: 60 Days
Originally Posted by ramairetransam
okay ,im newly procharged whats the big deal with the race bypass valve , whats wrong with the one with the p1 kit , or whats so good about the valve.
The standard Pro-Flow bypass valve works very well up to around 14 psi, past that you need a larger valve as there is more air to relieve.
Here is an older copy of the installation manual. http://www.ls1.com/ed/procharger_owners_manual.pdf Several things have changed in it, such as the pn# for the aftermarket harmonic balancer, which is now pn# 918853. Disregard the fmu (fuel management unit) section. Bob
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
Old Apr 1, 2011 | 12:03 PM
skyhighsami's Avatar
no title here
Why does it seem the larger blowers D1 and such have an extended tip of the impeller and the the smaller ones don't seem to? Just curious
Old Apr 1, 2011 | 12:06 PM
ChevyChad's Avatar
Are you talking about the nose cone thing?
Old Apr 2, 2011 | 08:43 AM
lbm13186's Avatar
bob do you know if i need a super dampner and if so do you know the part number for it.
chad ya i knew what Intercoolers were just didnt get the short hand and ya that is a great thing to keep in mind down the road (next winter) to increase the power didnt really think about the dual setup
Old Apr 2, 2011 | 02:54 PM
MadIceV8's Avatar
Customizing Director
Originally Posted by lbm13186
so i guess all i need to make this all work out would be a pinning kit if my crank is not keyed?
and big red race bvp
chad what r the dual IC's
and do i need to get the superdampner to get this system to work or could i get away without it for right now. Budget is getting close and would like to get it on the road but dont wana mess anything up at the same time.
Since you have that adapter hub you won't need to get the super-dampner. However it is recommended that you get one if you plan to boost the car past 10psi.
If you do you the adapter, the SDCE crank pulley bolts onto that adapter hub using 3 bolts, those 3 bolts will also hold that assembly in place against the 3 fins on the stock crank pulley. You'll also need to get a longer crank bolt from Procharger.
Procharger also sells a pinning kit for the stock crank setup. It costs ~$90 new and is highly recommended. You drill into the front of the crank and insert a pin to prevent slipping of the pulleys on the crank.
Old Apr 2, 2011 | 06:17 PM
lbm13186's Avatar
im not going to have the stock crank so idk what i should do?
Old Apr 3, 2011 | 09:36 AM
ChevyChad's Avatar
Does your crank have a keyway in it? If so, just go ahead and get the ATI superdamper since it has a keyway also. Hell, I'd recommend getting it anyways even if your crank was stock.
