Bye-bye bottle. Hello twins. LS Coupe refit.
Old Jun 13, 2011 | 12:17 PM
  #41
Phil99vette's Avatar
7 Second Club
Check out www.coneengineering.com, they make nice collectors that are inexpensive. Stainless and mild steel.
Old Jun 13, 2011 | 07:34 PM
  #42
LSmonster's Avatar
Originally Posted by madmax4499
I would use the collectors, in-fact where did you get them?
All the parts for these headers came from Stainless Works. (Flanges, J-bends and collectors)... And they are a board sponsor. And I've use Cone collectors before and they worked are great too.
Old Jun 14, 2011 | 12:49 PM
  #43
StainlessWorks's Avatar
We offer a variety of collectors, including a merge style collector that has a reverse cone at the very end.
For turbo headers, we dont like to use merge spikes which the collector above have. The reason for not using merge spikes on turbo applications is because we have actually witnessed the merge spike melting off on a set of turbo headers a guy built and particles flew into the turbo destroying a very expensive turbo.
Also, in our personal experience, headers with a reverse cone/merge collector and normal formed collector like Clay used above, showed absolutely no difference in power on a turbo car. On a naturally aspirated car, the collector does come into factor and thats why all of our headers have integrated merge spiked with our formed collectors.
Good work Clay, and thanks for the pics!!
Thanks
-Anthony
Old Jun 15, 2011 | 10:18 AM
  #44
CarsandWomen's Avatar
I stand both corrected and educated, thanks for that fellas
Old Jun 15, 2011 | 10:22 AM
  #45
Colemann's Avatar
Wooooweeee that is going to be nasty!!
Old Jun 15, 2011 | 10:08 PM
  #46
LSmonster's Avatar
Here are some mock up pics. As I said above, I'm not going with twins this time, just a big single... And this is just tacked together, but you can get an idea where I'm going with this.
Old Jun 15, 2011 | 10:22 PM
  #47
mpatton's Avatar
Sweet! Its clean
Old Jun 15, 2011 | 10:34 PM
  #48
JRracing's Avatar
Nice work man. I wish you were my neighbor. LOL.
Old Jun 16, 2011 | 06:48 AM
  #49
Yea, me too
Old Jun 17, 2011 | 10:22 PM
  #50
LSmonster's Avatar
Little more mock-up done. The hot side is almost finished. Just gotta weld everything up and fab the exhaust outlet. It will go out the bottom of drivers side fender.
Old Jun 18, 2011 | 11:01 AM
  #51
7 Second Club
Whats that like a 76mm turbo? J/K looks great.... Are those SPD flex sections?
Old Jun 18, 2011 | 11:06 AM
  #52
TracyRR's Avatar
That looks e'fn sweet!!
Old Jun 18, 2011 | 12:30 PM
  #53
LSmonster's Avatar
Yes, those are SPD flex joints. They are pricey, but after I saw this thread http://www.yellowbullet.com/forum/sh...ht=flex+joints I sucked it up a got them... This car will see a lot of street use so I didn't want any issues.
Old Jun 18, 2011 | 01:29 PM
  #54
Fb0dy0nly's Avatar
Those flex connectors look nice, def get what you pay for. Couldnt even tell the difference between ur home made headers and a bought pair, great fab work. Also like the placement of those wg's, clean setup for sure.
That turbo damn near blocks the whole engine in the pic! Make sure no small children are near when you start it up..
Old Jun 18, 2011 | 07:44 PM
  #55
LSmonster's Avatar
Thanks! The pic is kinda deceiving because the car is up in the air. With the hood on the car the turbo is about 5" below the hood... You would never think that by looking at that pic.
A lot of mock up time went into locating the turbo so it would fit with all the other stuff that will need to go in there with it... The radiator was the biggest challenge. The fans needed to go inboard (draw through) not out board (pusher) I live in AZ. where the night time low temps are higher than most cities day time highs. A wimpy radiator was not gonna cut it.
Old Jun 22, 2011 | 08:45 PM
  #56
LSmonster's Avatar
More mock up pics. Got the radiator mount mocked up and everything clears with 5" of hood clearance to spare! Now I will have no problem keeping this sucker cool in the heat on AZ streets!
Old Jun 22, 2011 | 09:33 PM
  #57
LS1PUNK's Avatar
Nice!
Old Jun 24, 2011 | 10:36 PM
  #58
LSmonster's Avatar
Got a little mock up done on the cold side. It's kinda hard to tell from this pic, but there is a drop down pan under the cowl that will have a bulk head couplers for the plumbing in and out of the intercooler. (Only one coupler is in there right now) This will allow me to separate the pipes (V-band clamps) from the car at this point. (the other points being the T/B and the turbo) It will make for a solid mounting point that will be easy to seal of the plumbing from the engine compartment. Note: The intake that you see is just for Mock up. I'll be using a Mast/Cary intake that I'll be modifying for boost using an elbow. The intercooler is mounted where the passenger seat was originally.
Old Jun 25, 2011 | 01:13 AM
  #59
dudeman's Avatar
looks good! with a hood that big i wouldnt be worried about clearance!
Old Jun 25, 2011 | 08:44 AM
  #60
how bout a pic or two of that sweet lookin sand rail on the right? coming along nicely
