problem with procharger breaking belt
Old Apr 12, 2011 | 03:23 PM
pdasterly's Avatar
Default problem with procharger breaking belt
Finally got trans fixed, now Im breaking belts. I spoke with a local shop that specializes in superchargers and turbos and he says my factory ati valve is too small and the extra boost makes the belt jump/break when the throttle closes. What are my options, add extra factory ati valve, upgrade to red race valve or get bov with boost controller. I'm leaning toward the bov with controller. I have this controller and bov left over from my turbo build
unknown psi, 347, d1sc 3.4 pulley
tuner is going to limit my tune with full timing to 15psi due to water pushing.
Old Apr 12, 2011 | 06:59 PM
AFASTYZFR1's Avatar
I never broke a belt with stock bypass at 15psi......but the plenum box exploded a few times
Old Apr 12, 2011 | 08:01 PM
pdasterly's Avatar
I have a fmic, pieced together my system
Old Apr 12, 2011 | 08:09 PM
AFASTYZFR1's Avatar
That makes no difference. I doubt you are breaking belts because of the bypass....belt would just slip.
Old Apr 12, 2011 | 08:25 PM
BigRich954RR's Avatar
F1c i did 17 psi with the cheapest procharger blow off valve had flutter noise but never broke a belt upgraded to red race valve when i had money
Old Apr 12, 2011 | 09:24 PM
Aster's Avatar
I would seriously recommend upgrading the bypass valve to a race valve. You are putting a lot of load on the internals of the blower if the air can't get out fast enough and backs up into it. Trust me when I say you don't want to crash the bearings on the impeller. You will be looking at a whole new head unit if that happens. It happened to me on the P1 using the proflow valve with a 3.4" pulley years ago and that was Procharger's diagnosis.
Old Apr 13, 2011 | 06:11 AM
AFASTYZFR1's Avatar
I suggest getting a race bypass too....but he has another issue. Check the belt alignment.
Old Apr 13, 2011 | 11:04 AM
Bob@BruteSpeed's Avatar
LS1Tech Sponsor
Active Streak: 30 Days
Active Streak: 60 Days
I agree on both accounts. Belt breakage has to be because of improper belt alignment.
Here is a link to where I sell the race bypass valves.
http://shop.brutespeed.com/ProCharge...alves_c347.htm Bob
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
Old Apr 13, 2011 | 12:11 PM
1FasstWS6's Avatar
I snapped my belt at the track, they found out that some of the brackets made by procharger was just a hair off which caused the belt to be off alignment and snap under load. The shop I use, Straightline Performance called procharger and they were able to help out with that and get a new one. So I'd say give procharger a call and see what they say. Hope that helps a little.
Old Apr 13, 2011 | 12:36 PM
ChevyChad's Avatar
8 sec potential, 12 sec slip
I like the idea of unbolting your head unit pulley, taking any spacers out from behind the pulley that you may currently have, then starting your car up and let it idle momentarily, then turn it off. This will allow the head unit pulley align itself. Then, carefully measure the spacing the pulley has ended up away from the head unit, and use that as your shim dimension.
Cant remember who suggested that, but I remember seeing it on here somewhere.
Old Apr 13, 2011 | 12:39 PM
LS1Tech Sponsor
That was Ron Sutherland who has a GTO. Bob
__________________
Old Apr 17, 2011 | 10:14 AM
Aster's Avatar
A Bit difficult to accomplish on an f body. Have you checked and made sure the belt isn't contacting the bracket itself? Also were you running an added pulley on a machined boutin stand off? Something there could be off.
