Pro charger install
Old Apr 13, 2011 | 09:48 PM
lbm13186's Avatar
Default Pro charger install
Hey guy i just got a f1 procharger and it was used so most of it is together already but i was wondering if any one had any tips for me b4 i start any help would be nice thanks
Old Apr 14, 2011 | 01:00 AM
blue00ZZleeper's Avatar
Do a search. There should be a decent amount of results. Be prepared to modify lol
Old Apr 14, 2011 | 06:23 AM
Bob@BruteSpeed's Avatar
LS1Tech Sponsor
Active Streak: 30 Days
Active Streak: 60 Days
http://www.ls1.com/ed/procharger_owners_manual.pdf
Here is an older copy of the ProCharger f body installation manual. The ATI Performance Products harmonic balancer has been replaced by their 918993 balancer, and disregard the fmu information.
I sell most of the items required to complete a ProCharger LS1 F Body kit at this link. http://shop.brutespeed.com/98-02-F-Body_c181.htm Bob
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
Old Apr 14, 2011 | 06:42 AM
LS1RedZ's Avatar
Yep, be prepared to modify a few things as said above, but other than that it is pretty straightforward.
Old Apr 14, 2011 | 06:46 PM
lbm13186's Avatar
thanks guys i have the install manual from the kit, but i do have one question right of the bat, i have the damper but i am wonder how it connects to the crank? if any of yall have pic or any part numbers that i can look up and c what is what? thanks guys
Old Apr 14, 2011 | 09:06 PM
cals400ex's Avatar
i use a new stock crank bolt for my ATI damper.
Old Apr 15, 2011 | 06:19 AM
LS1Tech Sponsor
These instructions should help you out. http://www.atiracing.com/products/da...structions.htm Bob
__________________
Old Apr 15, 2011 | 11:14 AM
skyhighsami's Avatar
no title here
What is the biggest Procharger you can bolt on a F Body and it's Max power it's make on a 390-410ish CI with an intake and heads to support out power
Old Apr 15, 2011 | 06:41 PM
lbm13186's Avatar
no high jacking thanks...
since i have the motor out already would it be easier to install the intercoolers now or anything else that would save time and effort or should i just wait until i get the motor and instal it then??
Old Apr 16, 2011 | 05:47 AM
LS1Tech Sponsor
Install the ATI Performance Products balancer and pin it to the crank, everything else can wait until the engine is installed. If you have an aftermarket crank, it may have a keyway in it so that you can install a key and not have to drill and pin the balancer. Bob
__________________
Old Apr 16, 2011 | 08:59 AM
Firehawk441's Avatar
I've seen a F2 and F3 on a F-Body. I don't know what you mean by bolt on though. Jakes Performance does a 3" belt drive setup with a crank support and then there's two companies that have a gear drive...
Max. power is as much as you can afford.
