LS9 Cam
Old Apr 16, 2011 | 08:11 AM
TT402LS1's Avatar
Default LS9 Cam
Anyone running a LS9 cam in there turbo engine? 211/230 .558/.552 122.5CL! Only $160.00 threw LPE!
Thanks - Ron
Old Apr 16, 2011 | 06:12 PM
TT402LS1's Avatar
No one?
Old Apr 16, 2011 | 06:34 PM
Hank Peabody's Avatar
You can search all over the internet and ask on 100 different forums and there seems to be no actual data where anyone is using it with turbos. You can get it for about $110 or something like that from GM parts direct. I got one and am tempted to dyno it just to see, its quite a mystery! I figure it'd have to make good power, any cam will, I just wonder if it makes the turbos spool slowly with the huge seperation.
Old Apr 16, 2011 | 06:43 PM
Summerwolf's Avatar
http://www.ls1gto.com/forums/showthread.php?t=404784
I know its not the same but here is an LS7 cam in an LS2
Old Apr 16, 2011 | 07:52 PM
tripblackls1's Avatar
there's already a thread with like four pages of discussion on it, try a search !
Old Apr 16, 2011 | 08:19 PM
1320's Avatar
gm parts direct is 97$.....or it was....
Old Apr 17, 2011 | 08:40 AM
TT402LS1's Avatar
Did the search. Read evreything. Still all I found was peoples opinions. I wanted to know if anyone was RUNNING this cam in their turbo setup? Seems like there is alot of back and forth on opinions on this subject, (both with valid points) but Im looking for someone that has ran the cam in a turbo setup.
Ron
Old Apr 17, 2011 | 08:02 PM
TurboAv's Avatar
If you are doing your own tuning and labor just try it. If you aren't I would spend the cash having someone custom spec a cam for you.
 Michael S. Palmer
Old Apr 17, 2011 | 10:30 PM
merim123's Avatar
it's not just the $150, you need the new covers too. LPE has all in the info on their site. It will cost 400 or so to experiment.
Old Apr 18, 2011 | 05:06 PM
stevieturbo's Avatar
Except it's essentially the same as a cam LPE have been offering for years. So there isnt really any experimenting.
just ask their advice.
Old Apr 19, 2011 | 11:31 AM
TT402LS1's Avatar
Yes were doing our own tunning. I have read everything about cost, pricing, etc... But, I was thinking someone has to had tried this or is using this cam in there turbo motor. Im not a cam expert, but have somewhat of a understand of them. And was thinking this would make a nice streetable, well mannard cam, that would make great power while still getting very good MPG.
Ron
Old Apr 19, 2011 | 12:29 PM
merim123's Avatar
that is basically what LPE says on their site. This is so close to what they use to offer, that they just stopped offering the LPE grind and use this exclusively. They can't compete with mass manufacturing on this part. So I'm with you, don't think there is any experimenting here. It is a 3bolt cam, but does need the different covers. That is the only reason I'd say if you want stock, go used ls6, and save about $200. otherwise a new ls6 cam is 289 at summit.
Old Apr 20, 2011 | 10:22 AM
TT402LS1's Avatar
I also hear their GT2-3 Cam works great! Anyone run this cam in their turbo setup?
Ron
