454 inches of turbocharged badness
Wow that is going to scream.
Are you going twin turbo or single turbo it?
and like the other guy said above it wont wind up very fast being such a long stroke, hence why when thompson automotive made their 2048HP twin turbo LSX they kept the bore at 4.125 and the stroke at 3.75 so it can rev right up and get the turbos working and it was only 400ci due to having a smaller stroke.
Top end it will make awesome power but it will take its time to get there.
7 Second Club
Our old setup was a 4" stroke and went to 8500rpms, this motor should be able to do 8000 fairly easily. It should be right around 7300-7400rpms at the 1/8 mile with 3-4% converter slippage. That will put us right around 175-179mph when its set on kill.
FWIW-while we plan on running this engine between 7500-7800- i wouldn't be afraid to take this thing to 9200 if needed. I've seen my fair share of 5"+ stroke bbc's that turn 9000 rpm
VA Speed builds something bigger than a 427? ![1poke](https://ls1tech.com/forums/images/smilies2/1poke.gif)
Can't wait to see what you guys do with the new bullet! Still running the 106 on this one? Sounds like you're building with the focus of 1/8th mile?
![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
#32
FWIW - You should have stopped after "...9200 if needed."
Big Blocks are a different animal with different crank journals.
You are alleging that you are comparing apples to apples.
Even CCW there is a limit to throw in an LSx crank, Bryant or not.
You don't need to justify your engine combinations.
You know what you are doing.
People will second guess you no matter what you do.
Don't get sloppy with your responses and risk credibility.
Thanks for sharing, I admire your work.
I look forward to seeing the fruits of your labor.
Best of luck with it.
![Chug! Chug! Chug!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_chug.gif)
#33
Shawn,
Best of luck with it.![Chug! Chug! Chug!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_chug.gif)
Thanks, I'm not justifying anything-as you say I don't need to. People see long stroke engines and automatically think that the stroke is the limiting factor for rpm. When in fact pretty much every time the limiting factor is the valvetrain. The BBC was an extreme example of this-not an apples to apples comparison.
#34
Yes,this def will be mainly an 1/8 mile deal. We have changed the turbo,out with the 106,we have some new turbo technology going in. It should be fun-we're trying out alot of new technology in this engine,so I hope it works how I have it planned
#36
<shawn and his expertise>
Yes,this def will be mainly an 1/8 mile deal. We have changed the turbo,out with the 106,we have some new turbo technology going in. It should be fun-we're trying out alot of new technology in this engine,so I hope it works how I have it planned![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
