Procharger guys
Old Apr 22, 2011 | 09:32 PM
SS LeadFoot's Avatar
Default Procharger guys
Has anyone ever replaced the rubber hoses that come out of the air box with metal or something else? I was thinking of having something made so that it looks a little better. Wonder if anyone has any ideas on possitive and negatives.
Old Apr 23, 2011 | 07:58 AM
KrisXpc's Avatar
Ive seen it... I dont think it looks any different. It's still pipes of some shape and form coming out of the box and going down.
Old Apr 23, 2011 | 09:02 AM
Bob@BruteSpeed's Avatar
LS1Tech Sponsor
Active Streak: 30 Days
Active Streak: 60 Days
You could replace the rubber hoses with silicone, but you want to make sure you use quality 4 or 5 ply silicone. You could also convert over to the front mount intercooler assembly that ProCharger recently came out with. Here is a link to it which has a lot of pictures included. http://shop.brutespeed.com/ATI-1GJ11...-1GJ115-IC.htm Bob
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
Old Apr 23, 2011 | 03:19 PM
Bob what kind of piping is that, that comes from the TB? Thats what I'm looking for. Dont really want to go with the FMIC because of the $ and I dont want to modify the front of the car.
Old Apr 23, 2011 | 03:41 PM
LS1Tech Sponsor
Because you have two intercoolers you have two pipes running up into the plenum box. It would be difficult to get rid of the plenum box when you're running the twin intercoolers. Bob
__________________
Old Apr 23, 2011 | 03:54 PM
I dont want ot get rid of the plenum box, just want to have the piping that comes from that box the same material as the FMIC. It looks to be solid not rubber like what I have.
Old Apr 23, 2011 | 04:02 PM
LS1Tech Sponsor
The FMIC does not have a plenum box because there is only one pipe running into the intercooler and one running out. You have two intercoolers so you have to set of pipes, which is why you have a plenum box with two pipes going into it, then one going to the maf. You could replace some of your tubing and rubber with aluminum, and use silicone in between. Bob
__________________
Old Apr 23, 2011 | 04:34 PM
the two rubber tubes that come out of the plenum box is what I want to replace. I want to replace them with the same material as is used on the FMIC. Do you know what material that is? Thanks for all you help BTW
Old Apr 24, 2011 | 04:00 AM
KrisXpc's Avatar
Originally Posted by Bob@BruteSpeed
You could replace the rubber hoses with silicone, but you want to make sure you use quality 4 or 5 ply silicone. Bob
Bob already stated what to use.
Im thinkint it would be a PITA to get the silicone hoses to bend in the manner the rubber hoses are bent to do the replacement..
You really think it looks that bad??
Old Apr 24, 2011 | 05:37 AM
LS1Tech Sponsor
The tubing used with the front mount is made out of steel. if you have the polished aluminum plenum box you could probably have someone make bend up some aluminum tubing and have it tig welded to your plenum box, but it would be fairly expensive. Bob
__________________
Old Apr 24, 2011 | 06:54 AM
Thank you, that is what I was looking for. My two rubber tubes are a faded black and look more gray than black. I would like to get them steel if I could but will settle for aluminum. Thank you all for your help.
Old Apr 24, 2011 | 10:42 AM
Aster's Avatar
Hey there's a pic of my old twin kit. :-)
It would probably be better to work with aluminum, and you would not have to deal with rust.
Old Apr 24, 2011 | 11:18 AM
madball's Avatar
You could merge the inetercoolers like the LT1 procharger setup and delete the upper box. Would just have to move the piping and fuses around.
Old Apr 25, 2011 | 11:12 AM
Bad30th's Avatar
I did, made this Frankenstein setup out of stainless. Much less flex, boost comes on QUICK due to no expansion of the intercooler piping. Still uses the ATI twin intercoolers, just replaced all the rubber flex tubing up top and made a new plenum.
Running about 10psi I popped two plastic ATI plenums and popped/repaired an ATI aluminum plenum twice before doing this setup. No problems since.
Rob (Bad30th)
Old Apr 26, 2011 | 06:49 AM
Bad30th that is exactly what I want to do! What material did you use to replace the rubber hoses?
Old Apr 26, 2011 | 09:05 AM
ramairetransam's Avatar
more pics of that setup everything you got post em up
Old Apr 26, 2011 | 09:12 AM
Bad30th's Avatar
A local shop fabbed it for me a few years ago. It's 2.5" stainless steel for the charge pipes, and the plenum is made from welded cutout pieces of stainless. It polished up nice.
Thanks,
Rob (Bad30th)
Old Apr 26, 2011 | 09:15 AM
Bad30th's Avatar
Here are a few more pics :
Enjoy !
Rob (Bad30th)
Old Apr 27, 2011 | 04:45 AM
KrisXpc's Avatar
I had my stock Twin pipes powder coated black without knowing I wouldnt see a single one of the pipes
