Pushrod length recommendation
Old Apr 24, 2011 | 12:02 PM
XtremeDime's Avatar
Default Pushrod length recommendation
Im hoping someone might be able to give me a recommendation on pushrod length. I have a stock short block, GM MLS gaskets and a VA Speed VTC 2 cam. Stock rockers and unmilled 317s. I cant find what the intake/exhaust base circles are on the cam so maybe someone here might know or has one of these cams with a similar setup.
I would measure them but Ive never done it before and dont fully understand the process >.<
Old Apr 24, 2011 | 03:45 PM
van383's Avatar
i would call va speed and ask them what pr goes with that cam.. typical 7.400 to 7.425 should be it, but i would call them seeing its there cam first..
Old Apr 24, 2011 | 08:50 PM
XtremeDime's Avatar
I couldnt get a recommendation from them over the phone but I understand where they are coming from. Its not like I have a custom 1 off setup so I was wondering if someone had a similar setup and could tell me what they went with.
Old Apr 24, 2011 | 08:53 PM
ablakez28's Avatar
http://www.latemodelrestoration.com/...-Checking-Tool
I would say 7.4 but it is pretty easy to just check and then you get to have more tools!
Old Apr 24, 2011 | 09:47 PM
XXX37's Avatar
7.4 also...
Old Apr 25, 2011 | 12:13 PM
Fireball's Avatar
7.400 is probably ok...
most custom comp cams and stock heads work well with a 7.400
Old Apr 26, 2011 | 08:24 AM
XtremeDime's Avatar
I have some factory 7.4s lying around. I just need to install them, tighten down the rocker and make sure there is no play and it feels solid?
Old Apr 26, 2011 | 08:32 AM
Fireball's Avatar
not quite that simple...need to figure out how much preload you have.
Old Apr 26, 2011 | 08:33 AM
XtremeDime's Avatar
GAAAAH, how do I check that? lol
Old Apr 26, 2011 | 02:42 PM
ablakez28's Avatar
Why don't you grab the length checker I posted up?
Old Apr 26, 2011 | 03:05 PM
TX RED's Avatar
I would like to know as well on how set pre load
