Supercharged set up
Old Apr 24, 2011 | 12:54 PM
2000z28ss's Avatar
Default Supercharged set up
I recently spun a crank bearing on my basically stock LS1 block. I'm Gunna be tearing it apart and replacing that, so while it's out, I was wondering if I could get some help with a set up for it that would include a supercharger, or turbo. It's still going to be a daily driver, so I want it to be able to run on the street daily. Help would be greatly appreciated, where I haven't built an engine before.
Thanks!
Old Apr 24, 2011 | 01:31 PM
ChevyChad's Avatar
8 sec potential, 12 sec slip
What are your goals for the car?
Old Apr 24, 2011 | 01:44 PM
2000z28ss's Avatar
Um, something around 5-600 horse maybe more, but still reliable for daily driving, fairly cheap, but not sacrificing reliability for money, decent MPG, fast, my car has 4.11 gears so something with a decent power band, but that I'll still hook up.
Old Apr 24, 2011 | 02:34 PM
ChevyChad's Avatar
Hit up Bob at brute speed for a D1SC kit. Probably the most straight forward, proven, and reliable FI setup out there. You can get everything from Bob to just bolt it on and go.
Old Apr 24, 2011 | 03:16 PM
2000z28ss's Avatar
Is it just the charger kit? Cuz won't I need heads and all that? Cuz I gotta take everything apart. Hope I didn't wreck my crank case and or shaft.
Old Apr 24, 2011 | 03:27 PM
ChevyChad's Avatar
You can get by with stock heads. If you want to replace the heads, go with some 317 truck heads. They will be more boost friendly by helping to lower compression.
Old Apr 24, 2011 | 03:32 PM
2000z28ss's Avatar
Cam too? I'd shud I leave the stock cam? I want it to be built right. Don't really wanna have to take it apart again
Old Apr 24, 2011 | 04:01 PM
ChevyChad's Avatar
If you want my complete opinion, build a forged 347 with stock crank, compstar rods, either diamond or wiseco pistons (aim for about 9.0-9.5 SCR), either speed inc SC2 cam or brute speed cam, LS2 timing set, LS7 lifters, hardened pushrods, patriot gold springs, and stock 317 heads. If you have the funds to get better heads, dont waste money on a stock ported head, get aftermarket heads with thicker decks. Make sure to get ARP head studs (main studs would be good also if funds allow).
This setup will allow you to make full use of the D1SC. Start with relatively low boost (~8psi or so) and that will get you right into the range you want of 5-600 at the wheels. Once you are ready to step up, you are just a pulley swap (and a tune) away from another couple hundred rwhp without having to worry about your engine having to come out again, or having to swap out blowers.
I'd recommend going with a SD tune right from the start instead of screwing around with a MAF bandaid tune. May as well start with a 3 BAR to begin with which will allow for future upgrades down the road.
All this has a pretty high cost initially, but will save you tons of money in the long run. Trust me, I did it the hard and expensive way.
Old Apr 24, 2011 | 04:31 PM
2000z28ss's Avatar
What you think the cost will be roughly? I'm just trying to figure out the price right now so I can start saving money.
Old Apr 24, 2011 | 05:15 PM
Bob@BruteSpeed's Avatar
LS1Tech Sponsor
Active Streak: 30 Days
Active Streak: 60 Days
Thumbs up
Thanks!
http://shop.brutespeed.com/ATI-1GJ20...-Speed-Kit.htm
Here is the ProCharger D-1SC kit that I also add the extra items to it that are required. I recommend going with the Aster bracket and the front mount intercooler options. Bob
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
Old Apr 24, 2011 | 05:23 PM
youngrigo's Avatar
Definitly go with the Aster bracket and front mount from the start...
Old Apr 24, 2011 | 05:33 PM
2000z28ss's Avatar
The race intercooler upgrade?
Old Apr 24, 2011 | 06:04 PM
93formto98T/A's Avatar
Do it right the first time; D1SC, aftermarket brackets, FMIC. You will be happy now and later when you want more.
Old Apr 24, 2011 | 07:07 PM
BlackChicken's Avatar
I know everybody is talking about prochargers, but if you can find a good shop to build you a turbo kit. It's just another option. My rear mount TA drives like stock unless I put it under load, then my 500+ HP comes out.
Old Apr 25, 2011 | 11:42 AM
2000z28ss's Avatar
Would this set up be street friendly? Or wud my mpg suck?
Old Apr 25, 2011 | 12:04 PM
2000z28ss's Avatar
http://www.texas-speed.com/shop/item...d=883&catid=88 that page, chevychad, there a bunch of diamond and wiseco piston options, any chance you could pick the right ones for me? Id appreciate it alot(:
Old Apr 25, 2011 | 12:08 PM
LS1Tech Sponsor
http://www.procharger.com/supercharger/blog/?p=14
Check out the above link. Bob
__________________
Old Apr 25, 2011 | 12:49 PM
ChevyChad's Avatar
Need to know what heads you will be running to determine your piston size.
Old Apr 25, 2011 | 12:52 PM
2000z28ss's Avatar
Also, will the 347 hook right up to the stock harnesses and all the sensors? Etc etc
Old Apr 25, 2011 | 01:23 PM
ChevyChad's Avatar
You need to do a LOT of research man. A 347 uses a stock block, just honed out some. So yes, everything will fit.
