Apex Bov on Procharger? Any ideas?
So i ran across a good deal on some spare parts. I already have an procharger Bov, And another penlium But i got this with some other parts i needed. And i was wondering. Because i haven't heard of anyone running much besides procharger bov, If this is any better or worse? or if it even works or any thoughts on the setup?
![](http://i6.photobucket.com/albums/y220/FlipediS/imagejpeg_0.jpg)
![](http://i6.photobucket.com/albums/y220/FlipediS/042311162553.jpg)
LS1Tech Sponsor
Blowers are always producing some amount of boost as they are belt driven, where a turbo spools up as the exhaust velocity is increased. Bypass valves are used with blowers since they always relieve the boost until near zero vacuum (heavy throttle) is achieved. Blow-off valves are designed to relieve boost at a set amount of boost, and can cause boost stacking when used with a blower. Light springs can be used with blow-off valves so that they can be used with blowers, and many have reported success with doing so. Unless a blow off valve is properly set up with a light spring though, the boost that is built up places a load on the blower that is hard on it, plus it will try to slow the blower down which can cause belt slippage. Stacked up boost will also try to find weak spot in the tubing and hoses to blow out of. Bob
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
![](https://ls1tech.com/forums/signaturepics/sigpic168855_1.gif)
So, If the BOV was set so it was open at and idle and low rpm it would work? Also from what i read. Pro chargers are set up and don't produce much power tell higher rpm? I was reading an on some forms where they talked about putting a restricter plate on it to make boost to come in at a lower level. Well wouldn't a BOV that close earlier just create the boost to come in sooner?
Sorry im totally new to all this and just trying to get a proper understanding. And thanks again for all your help and feedback
LS1Tech Sponsor
__________________
Cant thank you enough.. thanks again. Really cant wait to get mine together and in. but it will be as bit long since i ran in to a small financial step back. I i had the money to just buy the rest i needed from you i would. But for now got to keep just picking up what pieces here and there for now.
adjust, adjustment, apex, blow, blowers, bov, calculation, ls1, plate, procharger, procharver, restrictor, set, setting, valve
