Advice from high hp sts owners
If you're on a budget, I'd go with 243 heads if you're going to run E85, and 317s for gas.
Stick with the stock LS6 intake for that hp.
Injectors will depend on what fuel you want to run. 80s would be a minimum. If you want to run E85, I'd go 160s.
Use stock manifolds, and wrap all of the hot side pipes.
It's going to be a touch laggy. You won't have much backpressure worries with the turbo in the back. E85 would help spool a bit.
Good luck.
Reason being, piping is too small, their is alot of ground clearence to be had from a custom setup, and stepping pipe sizes, etc. The STS kit just has far to many flaws for a "HIGH HP" build.
I would suggest if you are set on a rearmount turbo, Search "ZOMBIE Rearmount turbo saga" and begin reading.
Also, Longrange4u has lots of info here as well.
others chime in. there is a lot in the setup of this...
If your set on a pt88 look into a quick spool valve
That pt88 is going to be really laggy unless you do everything exactly right.
And as zombie said, you need to do everything right and keep as much velocity as possible to spool that bad ****! 2.5" piping from the y pipe back might be your best bet
