Help from pro charger guys
first i started out by building a 6.0L forged motor and went with Brute speeds blower cam.
then i went with lonnie's performance on the fuel system
kooks headers
bought a f1 procharger system with dual intercoolers from a guy used (going to switch to the front mount next year)
using 60lb injectors
Gage and Wide band O2 Air/Fuel ratio
aligment
exaust
tune
clutch should hold up
hoping stock rear holds up until next winter
if anyone see's that im missing something please let me know
should have the engine back next week and putting it in asap and wont to get this thing to start right up and not have any problems
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
But on a side note. Sounds like you have your ducks in a line though otherwise but plan on having lots of little stuff come up
But I agree, sounds like the OP has things planned pretty good at this point.
To be honest, I didnt break my rear end on my procharger setup until I actually went to the track and put drag radials on it. I drove around on the street just fine for a pretty good amount of time. As long as the street tires are the limiting factor, you can protect your rear end. I never got a pass at the track tho with a 10 bolt. First time ever with a procharger, got to the line, light turned green, dropped the clutch and the driveshaft let go. Called a friend and he brought his steel DS to me at the track, got back in line, got up to the lights, and then second drop of the clutch, the rear end let go. After that, I borrowed my buddys stock 10 bolt for 6 months while I saved for a 12 bolt.. I'm just surprised you ran at the track with a 10 bolt and 6 speed with a procharger! The Best V8 Stories One Small Block at Time
if you guys think of anything i should upgrade let me know
To be honest, I didnt break my rear end on my procharger setup until I actually went to the track and put drag radials on it. I drove around on the street just fine for a pretty good amount of time. As long as the street tires are the limiting factor, you can protect your rear end. I never got a pass at the track tho with a 10 bolt. First time ever with a procharger, got to the line, light turned green, dropped the clutch and the driveshaft let go. Called a friend and he brought his steel DS to me at the track, got back in line, got up to the lights, and then second drop of the clutch, the rear end let go. After that, I borrowed my buddys stock 10 bolt for 6 months while I saved for a 12 bolt.. I'm just surprised you ran at the track with a 10 bolt and 6 speed with a procharger!haha my TA has had DR on it since the first month I bought it. Went 12.7s stock with DR and went 11.9s with ls6 cam and bolt ons. Then went procharged. Didn't take it to the track until the end of the year knowing I was getting the 9 in over the winter. However I made probably 40-50 passes at 600rwhp ranging form 11.2-10.5
